Question about Canon iR 2022 Printer
My photocopier whish is iR2022 says system error 007how can i know the part caurses this problem. This problem has started yestarday morning and what i have tried so far was to check the toner and drum if are properly fixed but foresure they are. so i am just stranded now for i am knowing nothing what can be the next step or solution for this problem.
  • Canon Expert
  • 316 Answers
E007 Fixing film rotation error
Posted on Apr 08, 2011
Hello i have a canon ir2022 displays "load paper drawer 1" at start up.
If there is paper in drawer 1 and you still get this error, it sounds like a bad paper sensor.
May 27, 2015 | Canon imageRUNNER 2022 Grayscale Copier
Error code 002-0000 for canon ir 2202
Hi
A website I have found gives the details of this error for the IR2016 and the IR2022 as the same.
Description Low temperature during temperature control.
The target temperature is not reached during temperature control. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Amongst other codes you can find it here:
Error Codes Canon iR2022
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 25, 2014 | Canon iR 2016i Black and White Copier
Dear sir i has a copier Canon IR2022 when i copy a file it give message ( system error 007 or system Error 003) how can i resolve the problem. thank you much
Possible torn out fixing film. Or dirty reference white plate on your fixing film. To resolve the problem, try replacing the fixing film unit or call the nearest authorize service center.
Aug 14, 2013 | Canon iR 2022 Printer
How i do scanner in canon ir2022
connect computer to network
install canon color network scangear, select printer ip in this software.
now you need scanning software.
I'm using freekapture.
place document in printer scanner. click scan button on printer.open freekapture and start scanning
Jul 06, 2012 | Canon iR 2022 Printer
Hello I have a canon ir2022 copier. I did a complete cleaning of all copier and when I recovered after having switched on a message error code e197. I controlled everything but I can not get from this...
Dear Mokhtar,Error code E197 indicates that laser scanner does not work properly. It's seems that you should try to replace this parts (Laser Scanner Assembly). Please download the following piece of IR2022 parts catalog to see detail of laser scanner assembly:Laser Scanner Assembly
I'm sorry for being late responding your problem and you don't have to pay for this :).
Regards,Xanda
Oct 03, 2011 | Canon iR 2022 Printer
Abs light not turn off
THE LIGHT ONCE ON INDICATES THAT THERE IS A PROBLEM WITH THE SYSTEM, ARE ALL THE TYRES OF THE SAME SIZE? REMOVE ALL THE WHEELS AND INSPECT THE SENSORS AND THERE WIRE CONECTIONS A BROKEN SENSOR WIRE OR TRIGGER WHEEL WILL CAURSE THE LIGHT TO COME ON, ALSO IF DIRTH GET STOCK BETWEEN THE SENSOR AND WHEEL. AS THE WHEELS ARE OF CHECK FOR LEAKS ON THE SYSTEM LOW FLUID PREASURE WILL CAURSE THE LIGHT ON IF ALL THAT CHECKS OUT OK THEN CHECK THE ABS FUSE.
Aug 25, 2011 | 2004 Ford Ranger
Hi I just put togheter a pc yestarday evga p55 le mobo , i5 760 dualcore cpu ...4 g of ripjaws...when i started the pc i had black screen and the debug light sad d3 on it...what i do?
something hanging up system go back to min config one memery dimm,display, then keep adding components till it repeats error thats the problem child
Jan 07, 2011 | Computers & Internet
System error E007 Canon IR2022
Hi
I have problem with my canon Ir 2020 after 3 or 4 copy it shows Error E007 .. and some times when i turn on the copier it shows this error .
How can I Fix this error ... please help me .
Thank You in Advance.
Oct 24, 2010 | Office Equipment & Supplies
Canon irt 2022 says "system error 007"
dear sir !
my canon ir2022 has one problem which is system error E007 how i can solve this above problem , i am wait for your answer .
Thanks & Regards.
Nayeel
Aug 13, 2009 | Canon iR 2022 Printer
Canon iR 2022 Printer Logo
166 people viewed this question
old marine
old marine
