Question about Toshiba Satellite M205-S7453 Laptop AC Power Adapter (19V/6A 120Watts) by Amstron (Generic) AC Adapter
Toshiba Laptop M 205 hangs, shuts off when connected to AC power pl. help.
    Problem Solver:
  • 5 Answers
Solutions :-
THIS IS BECAUSE OF MOTHERBOARD PROBLEM, U NEED TO REPLACE CAPACITOR PACK WHICH IS AVILABLE BOTTOM OF MBD
thanks...........
find me on google :- LAPNOSYS
Chip Level Motherboard Expert
Posted on Jan 04, 2013
2 Suggested Answers
domotek
  • 591 Answers
SOURCE: my laptop hangs everytime i
the power supply is defective replace it, because it does not provide the reqired AMPERAGE to your laptop STOP USING IT it could dammage the laptop... or it could be the battery for a sure test boot the laptop using just the power supply remove the battery (ONLY ONCE JUST FOR A TEST) if all is good (with just the powersupply) you could try a new battery with the power supply TOGETHER to confirm the problem
Posted on Jan 18, 2011
My toshiba laptop wouldn't work well when connected to power source but will function well am using the battery
Laptop shuts off when AC adapter plugged in
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard
Jun 20, 2011 | Toshiba Computers & Internet
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Toshiba Satellite A305 AC Adapter
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
Whenever i use my laptop's powersupply, my laptop unit hangs. instead i could only use my laptop using the battery alone and not with the power supply provided. my laptops model is toshiba satellite...
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard.
Reference: Toshiba Satellite A205 Power Adapter
Jan 17, 2011 | Toshiba ADP-75SB AB AC Adapter - 90 Watt...
Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
Laptop won't run on ac power and keeps shutting down
Check that the AC power works, go to a repair shop and test a different one or have voltages checked with a multimeter.
If the AC adapter is fine, then it is usuall because AC socket solder joints on laptop are broken. In this case , it is a delicate repair, and must be done by an expert repairman.
Dec 13, 2008 | Toshiba (K000006610) for Satellite P25...
Toshiba Satellite A135-S2276... went in sleep mode.
Try pressing power button once. Does Windows logon screen come up?
Jan 13, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite M205-S7453 Laptop AC Power Adapter (19V/6A 120Watts) by Amstron (Generic) AC Adapter Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
