Question about Panasonic Cell Phones
Registering handsets for KXTG9331 - Panasonic Cell Phones
  • 1,188 Answers
Please repost with what have you tried to do and do you get any errors? I do not have a question only that the handsets are registering. Post a question so I may assist you.
Thanks!
EJ
Posted on Apr 08, 2011
How to register the extra cordless handset of vtech 15250
Add and register a handset
Each newly purchased handset must be registered to the telephone base before use. When first purchased, each expansion handset shows NOT REGISTERED.
You may need to charge the phone first.
To register a handset:
    ·Place the unregistered handset in the telephone base or charger. Press Find for 4 seconds. If the headset screen doesn't light up after the 4 seconds. You will need to charge it some more.
    ·After making sure it is charged set the telephone on the main base again press and hold the Find button for 4 seconds ( until the red light IN USE comes on) Then release the find button. The headset will show PLEASE WAIT; this takes about 10 seconds to complete the registration. The hand set will show HEADSET REGISTERED and the headset number assigned, you will hear a beep when the registration is finished
    ·When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset is HANDSET 3.
    ·Makes sure no other headsets are in use at the time or the registration may fail.
    ·You cannot register a handset if any other system handset is in use. Only one handset can be registered at a time.
Aug 18, 2017 | Vtech Lands Phones
I just bought the Panasonic KX-TG9341T. This model has 4 remote extensions. My problem is the light on top of each phone keeps blinking. I checked to be sure I don't have any messages or anything else,...
The message indicator lights up when you have a new voicemail message, answering machine message, when you are receiving a call, or when the handset is placed on the charger. You can change the setting for the voicemail indicator and message indicator by pressing [MENU], [#][3][4][0], and press [▲] or [▼] to switch between off and on, then select [Save]. It is not possible to turn off the LED for an incoming call, or while it is on the charger.
Good luck...
Sep 05, 2008 | Panasonic Lands Phones
My V-TECH CS6229-3 phone base does not register the base phone but i can change another phone on this three phone set and it is registered and the phone
Is the handset you are trying to register de-registered? if not it will not register to another base until it is.first de-registered.
To de-register the handset do the following-
With a charged battery in the handset Enter *331734# then without pause Press and Release the Menu Select Button. You will hear a Beep. Handset would then be De-registered..
Then place the handset on the Main Base cradle and follow the instruction that come up on the handset display.if the handset still does not register then most likely the base memory is full and will have to be re-set .
To re-reset the Base:- Remove any handset from the main base cradle. Then Press and Hold the Locator or find HS or handset Locator button until the IN USE light comes on and begin to flash then release it and immediately with out pause press and release it again. That will re-set the base memory. All your handset will then be de-registered and will to be re-registered. Place each handset to be re-registered on the Main Base cradle and follow the instructions on the the handset display and they will register.
Sep 06, 2016 | Lands Phones
Reset mobile to main
To register a handset to the main base unit please follow the below link to obtain the detailed instructions.
http://service.us.panasonic.com/OPERMANPDF/KXTG9331.PDF#page=30
Apr 26, 2014 | Panasonic KXTG9344 Phone
I cant dial out it says register HS i am not familiar with the procedure.
When you reset a handset (or if you buy a new one1, that handset displays a Handset Not Registered message. If you see this message on a handset, you need to register it to a base before you can use it.
Registering a handset
Does the handset fit in the base cradle?
Yes
No
Place the handset in the base.
The display should say Handset Registering.
1. On the base, open the menu and select Register Handset. The display should say Handset Registering.
2. On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
In about 30 seconds, the handset display should say Registration Complete. Press TALK ( )/FLASh and make sure you get a dial tone. page29image32024
27
If...
Try...
- you don't hear a dial tone- the display says Registration Failed
Making sure the handset is fully charged, then start over at step 1.
To register a handset to a different base, see the section "Expanding Your phone" in the user's guide for the other base.
Mar 18, 2014 | Uniden DECT 6.0 Cordless Phone ID
Vtech cordless handset CS6209 will not connect with CS6229-2 base
Yes. The'old' handset must be de-registered from its
original base and then registered to your base.
NOTE: the CS6229 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
( if needed, else skip ahead to ( III ). )
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !! --
Jun 08, 2013 | Vtech Lands Phones
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
I need to deregister missing handset #1
To de-register HANDSET #1:
1) Grab any working handset which is registered to your base (so HANDSET #2 or #3 in your case)
2) Press and hold the "END" + "#" key for 5+ seconds (wait for it to beep)
3) Choose the "Deregister HS" menu option
4) Pick HANDSET #1 as the handset ot de-register (since that's the "phantom" registered handset)
5) Once de-registered, you can de-register handsets #2 and #3 directly from each handset's "normal" menu interface (i.e. press "Menu", choose "Deregistration")
6) Thereafter, if you re-register your handset, they should start at HANDSET #1, then #2, and so on.
Aug 27, 2009 | Uniden TRU8866 Cordless Phone
Uniden Have problem
Dear....Fixya Team,
I'm Soontaree. Thank you for your reply email. I would like to let you know i'm already solved this problem. I just have a look from the Uniden Manual so i just follow them detail like as below,
Thank you for your help i will contact to you later if i have anything problem.
Have a great day.
Soontaree
Registering DSS7905 Accessory Handsets
Your phone supports a total of ten (10) cordless handsets. Handset(s) supplied in the box with the phone base are
pre-registered at the factory. If you purchase an accessory handset, you need to register the handset before use.
Only one handset can be registered at a time. When charged, pre-registered handsets display a handset ID number.
Handsets that have not been registered display.
Before registering the DSS7905 accessory handset, the battery pack MUST be charged for 15-20 hours.
To register the DSS7905 handset:
Place the handset in the telephone base charging cradle to begin registration.
During the registration process, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
COMPLETE. is displayed; the handset has been registered to the base. If REGISTRATION FAILED. appears,
please try these steps again. When you register an accessory handset to the base, the handset ID will be
assigned.
Note:
If an accessory handset has ever been registered to a base, you must reset the handset before you can
register it to a new base. See Resetting the Handsets on page 24.
Feb 10, 2009 | Uniden TRU9480 Cordless Telephone
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
Cell Phones Logo
Top Panasonic Cell Phones Experts
Rommel Balcita
ray gallant
Are you a Panasonic Cell Phone Expert? Answer questions, earn points and help others
