Question about Samsung TS-H552 (810884008760) Burner
My system not detect dvd+r/rw ts-h552 drive - Samsung TS-H552 (810884008760) Burner
  • Samsung Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 08, 2011
Will a ts-h552 DVD R/RW drive work with windows 98?
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Aug 07, 2011 | Samsung (TS-H552U/BEWN) (TSH552UBEWNBGE)...
My DVD/CDW-ROM drive is gone! It is a TSSTcorp TS-H552D How can I down load a new driver free?
Try the following link;
http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
If that doesn't work I suggest you install a free program called "Slim Drivers" and allow it to scan your system and locate the correct driver. I recommend noting which drivers you're installing so they can be rolled back should one of them not function properly.
http://download.cnet.com/SlimDrivers/3000-18513_4-75279940.html
Feb 19, 2011 | Gateway GT5408 PC Desktop
How do i set my TS-H552 as slave?
Look closely at the "back" of the unit.
Look for a 2-by-4 grid of pins, labelled:
* MA(ster)
* SL(ave)
* C(able)S(elect)
* SP(are)
Move the small "jumper" to the 'SL' position.
Aug 02, 2010 | Samsung TS-H552 (810884008760) Burner
My dvd writer will try reading dvd's or cd's but it stops and nothing pop ups on my screen. it is a dvd+-r/rw model ts-h552.
Try this quick fix :
What I suspect here is that you tried a bad CD or
DVD disk inside your drive, in that case, get a very
good lens cleaner to clean your drive first.
If that doesn't work,
Get a screw driver and trace the screw holding the
CD/DVD Drive to your system at the back of your
laptop, then unscrew it and remove your drive. If you
cant do this by yourself, just try and get a good
technician to do it for you. Then clean the interface
connecting the drive to your laptop.
After this, power up your system normally without the
drive connected.
Then shut down properly, and reconnect the drive,
making sure that its firmly connected.
Then power on again and check it in the system
BIOS if its now detected, then save and exit, then
boot your system properly again.
If it doesn't work after this, then I'm afraid you might
have to get another drive.
Hope this helps you out.
Apr 15, 2010 | Toshiba Style Bay DVD-RAM Drive Kit...
My computer will not recognize the DVD I need a driver for it I get a message no disk in drive It is a DVD RW CD RW model @ ts h562 is was made by toshiba samsung crop what do i do.
I have done a web search and can't find much on "ts h562"
I had a similar problem to this a while back where my driver for the dvd had become corrupted some how.
Before you start you might want to create a system restore point. Read the windows help on how to do this. Just in case this does not work or you delete the wrong thing by accident. Also have a quick read how to do a restore.
Go into into Control Panel -> Administrative Tools -> Computer Management -> Device Manager
Find the driver for your DVD drive and delete it. You just highlight it and press the delete key.
It may be under unrecognized devices with a question mark or exclamation mark on it.
Then right click on the machine on the top level run a detect new hardware and it should automatically recreated the device driver from files already on the system.
Good luck and I hope it helps
Jul 11, 2009 | Dell Computers & Internet
Cd burning problems
hello sir..i have a solution to your CD burning problem...sometimes if you are not regularly using your CD-RW drive then there are chances of CD-RW lense prob,so please do clean the lense using lense cleaner CD available in the market,even then if you not able to burb the CD then please do reinstall the software which you are using for CD burning...i suggest you NERO software for CD burning which is a user friendly software...
Oct 30, 2008 | QPS Que! Fire CD-RW Burner
HP 640a cd/dvd burner
methinks you have a major device issue. Check it through control panel, hardware devices to see if driver is happy or not/
Feb 18, 2008 | HP Pavilion a1240n (EG136AA) PC Desktop
Samsung TS-H552 (810884008760) Burner Logo
107 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
