Try stopping on a steep incline--does the heater stay warm? If yes, what you have is an air bubble that hangs at the heater hose until pressure from the water pump blows thru it as the engine speeds up. Park on an incline, open the radiator cap, run the engine until the thermostat is open, turn the heater on, crack open any/all bleed ports to release any trapped air, and fill the radiator to the neck. Wait until the level stops dropping and make sure bubbles don't continue to come up. If they do, you may have a blown head gasket that will keep forming these bubbles until you change the gasket.
Please let me know if you have any questions and thanks for using FixYa.
No, because it blows cold air when it gets hot. There is air in the system or the coolant is low. Intake manifold gaskets are a very common problem on these engines and if left unattended to can cause even bigger problems such as head gaskets if the engine over heats too much. Check the coolant level and if it is low, look for leaks at the water pump, radiator and especially the intake manifold where it meets the head. Also, pull the oil dip stick an/or the oil cap to see if it looks milky. If it does, there is coolant getting into the oil.
http://howtobyme.blogspot.in/2012/05/2004-toyota-tundra-oil-gauge-and-temp.html
Toyota 4Runner: Temperature Gauge Sensor
http://technoanswers.blogspot.in/2012/04/toyota-4runner-temperature-gauge-sensor.html
Temperature gauge sits over half way mark?
http://schematicsdiagram.blogspot.in/2012/04/temperature-gauge-sits-over-half-way.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
Temperature gauge keeps fluctuating up and down close to red?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
Temperature gauge on the dash quit working on Pontiac Grand
Prix?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html
Dodge neon gauges not working?
http://technoanswers.blogspot.in/2012/02/dodge-neon-gauges-not-working.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on
passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
1992 Lexus LS400: Engine overheats,
Antifreeze out of reservoir and heater Blows Cold Air?
http://whatisbyme.blogspot.in/2012/05/1992-lexus-ls400-engine-overheats.html
These details will help.
Thanks.
For car running hot and overheating issues, I suggest to you go
through this help links.
Click this link below and go through the
troubleshooting procedure to take care of the problems: ----
Car runs hot?
http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
All types of car overheating problems and
troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?
http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
overheating?
http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
through this help links. Click this link below and go through the
troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and
troubleshooting?
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
troubleshooting?
down close to red?
troubleshooting?
when heater is ON?
