Question about Britax Eclipse Si - Paris Convertible Car Seat
5 piont harness
Could you please help me with adjusting the harness
  • 3 Answers
Http://www.britax.co.uk/cms_downloads/Eclipse_Si_BBO61200.pdf
try this link the whole manual is there
Posted on Jan 03, 2009
SOURCE:
Does anyone know of a helpful measuring guide that will aid me in finding the right fit of harness for my German Sheppard?
I found one chart - I hope you find this helpful. Just remember to keep two fingers space between the harness and your dog when fitting the harness.
3/8x10 adjusts 8-10"
3/8x12 adjusts 10-12 "
3/8x14 adjusts 12-14"
1/2x16 adjusts 14-16"
1/2x18 adjusts 16-18"
1/2x20 adjusts 18-20"
1/2x22 adjusts 20-22 "
3/4x24 adjusts 22-24"
3/4x26 adjusts 24-26"
3/4x28 adjusts 26-28"
1x30 adjusts 28-30"
1x32 adjusts 30-32"
1x34 adjusts 32-34"
Jul 19, 2012 | Pets - Others
How to adjust mixture on lx 50 2t
Run the bike start at 2 1/2 to 3 out turn in slowly untill the bike runs rough and then back off (out) slightly at that piont idle is set
Feb 21, 2012 | Motorcycles
Adjusting quinny buzz harness for a newborn
Hi
This is not feedback we've heard before! Remember there are two places to adjust the harness - underneath the shoulder harness pads and at the waist position. To adjust underneath shoulder harness pads you need to undo the popper from the harness, slide the pad down the length of the harness and adjustment point revealed to make harness smaller.
Jan 03, 2012 | Quinny Buzz Jogger
Timing on a gs 750e
take off points cover turn motor by hand when 1st timing mark comes around gap non adjusrable pionts,turn by hand all way round till 2nd mark comes up set adjustable points this should get u close then use a timimng light and adj as nessicary by moving 2nd set of pionts.
Jul 09, 2010 | 1978 Suzuki GS 750 E
How do i adjust the flow rate (zero piont
the flow rate is adjusted by the dial on the spreader the higher the number the bigger the flow opening will be.
Dec 14, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Loud niose coming from my machine when spinning
  • Hi,
  • Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | Hotpoint WMA54 Front Load Washer
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Shoulder straps
You can contact EvenFlo directly, they will be happy to help you out: http://www.evenflo.com/ Evenflo ParentLink Department: 1-800-233-5921
Mar 31, 2007 | Evenflo Aura Traditions Travel System...
Britax Eclipse Si - Paris Convertible Car Seat Logo
195 people viewed this question
Top Britax Baby Gear Experts
Steve Allison
Steve Allison
Zarir Irani
Dorel UK
Dorel UK
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
