I need the frequency codes - Office Equipment & Supplies
  • 1,188 Answers
This problem was posted to the category for Scanners. You need to repost your question in the proper forum. You are asking for frequency codes but do not specify what product you are asking about and what frequency codes you are looking for?
Posted on Apr 08, 2011
Puxing px 777
I would check the mic hole in the face of the PMR_2 to verify if there is anything covering it IE. tape stickers debris wax paint anything of the like. Also if the radios are digital, they may use a DPL code. If you have the computer program to set the frequencies and associated programming cables, connect them to a computer with that same program and verify the frequency output they need to be the same frequency. Also, they may use a DPL code ( channel encryption code that keeps channels private on a common frequency) if so they need to be the same. If they are analog then you check the frequency and the TPL code if it has one. All codes/ frequencies must match for communication to happen between the radios.
Jan 25, 2014 | Radio Communications
Need frequency for my scanner cus i lost them.
G'day Leo
I am not sure exactly what frequencies your after but a handy site for you is http://www.radioreference.com/apps/db/?coid=1
It will list up frequency codes in different areas you select
Hope that Helps
Jaysan
Jun 16, 2012 | Uniden BC60XLT Handheld Scanner
Lost owners manuel. need code install instructions. and also how to clear off all old codes
There is no general reset function that will clear all of the frequencies (they're not codes) from your scanner, but there are two ways to clear individual frequencies:
1. Programming "0.0" (zero point zero) into a channel will remove the programmed frequency.
2. Programming a new frequency into any channel will remove/override the previously programmed frequency.
You can download and print the manual for your scanner, at no cost, here:
http://www.uniden.com/pdf/BC248CLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Nov 16, 2010 | Uniden BC248CLT Base Scanner
Need code for columbia co. ga 30907
1. Type in this URL address-http://www.nws.noaa.gov/nwr/indexnw.htm.
2. Click on your state
3. Find the county you live in. The S.A.M.E. code should be listed in the "SAME#" column. If you have two codes for your county, it probably means one of the codes transmits for different regions of your county. No problem, all you have to do is check your frequency station. Whatever frequency receives the best reception for your county (for example 162.450), put in the S.A.M.E code for the county that has that frequency.
Aug 18, 2010 | Midland WR-100 Weather/RDS Radio
I cleared my scanner pro-82 now how do i program the channels back. the bank1 is blinking and is on channel 1. i do not have any scan codes for local fd/pd in the 78801 area zip code.
For a comprehensive database of active frequencies in your area (they're really NOT codes), visit:
To program known frequencies into your scanner,
1. Press PGM. PGM appears. Then enter the channel number (1-200) where you want to store a frequency, then press PGM again.
2. Use the number keys and DELAY/. to enter the frequency (including the decimal point) you want to store.
3. Press ENT to store the frequency into the channel.
Your scanner automatically rounds the entered frequency down to the closest valid frequency. For example, if you enter a frequency of 151.473, your scanner accepts it as 151.470.
Press DELAY/.if you want the scanner to pause 2 seconds on this channel before it proceeds to the next channel after a transmission ends. The scanner also stores this setting in the channel.
To program the next channel in sequence, press PGM and repeat Steps 2 and 3.
Need the full manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
BillB
Jan 19, 2010 | Radio Shack Pro-82 Scanner
I need to know frequencies and how to program a bearcat 148xlt
To program the Bearcat 148xlt, press the manual button and then enter your code, for example:"123.456" after you enter the code, push E and then press the manual button again to enter a new code like "567.987" then press E, when all of your codes are entered press the scan button to finish. Try http://www.scannermaster.com
or http://www.radioreference.com for some frequencies to add to your scanners database
Dec 16, 2009 | Car Audio & Video
Moved to another county.need to know how to program my scanner to here
hELLO THERE:
Here is a extensive list of links to scanner codes acrost the UNITED STATES
i REALLY HOPE THAT YOU FIND THIS VERY HELPFULL
BEST REGARDS MICHAEL
Scanner Frequencies Database of old scanner frequencies for thousands of cities across the country. http://www.cityfreq.com/ - 6k - Similar pages RadioReference.com - Scanner Frequencies and Radio Frequency Reference The world's largest scanner frequency and radio communications reference source,
featuring a complete frequency database, trunked radio system information, ... http://www.radioreference.com/ - 17k - Similar pages RadioReference.com - Scanner Frequencies and Radio Frequency ... Scanner Frequency and Radio Communications Reference Database. http://www.radioreference.com/apps/db/ - 62k - Similar pages SCANNER FREQUENCIES - Online Database - Find Scanner Frequencies ... Scanner Frequencies Database, Police, Fire, Rescue, Racing Frequencies, Airport,
Railroad, Taxi, Amateur Radio, Ham Radio Call Signs. http://www.nationalradiodata.com/ - 18k - Similar pages Scanner Frequencies & Codes Similar pages
Nov 11, 2009 | Uniden BC350C Base Scanner
Need free codes for a base police scanner
hello there
please try these links they have worked for me
  1. Scanner Frequencies & Codes Free Trunked Fleet ID's for your area (Works with Scancat) Military Base Operations Frequencies ... Get a scanner frequency list by email for your county, ...www.bearcat1.com/free.htm - Cached
  2. Portland Police Scanner | Portland, Oregon Crime & Emergency Dispatcher ... ... use of a Trunk Tracking Scanner and entering the Talkgroup codes listed in the next section. ... your Business Listing for free. Obits / Death Notices ...oregonlive.com/policescanner/...?/policescanner/police_codes.frame - 64k - Cached
  3. Scanner Feeds ... Feeds Police Codes Police 11 Codes General Codes General Acronyms ... They are free. ... Big Bear, California Police Scanner (web-based) Los Angeles Police ...members.shaw.ca/crazykid755/scanner - Cached
Sep 15, 2009 | Uniden Radio Communications
Frequency codes for the Uniden 50XL
depending on where you are, you can search the internet on google for radio frequencies, and your region name, and you should find some there
Jun 19, 2009 | Radio Communications
Police scanner codes
i need help to find free police and fire scanner frequencies
Nov 10, 2008 | Uniden BC350C Base Scanner
49 people viewed this question
jasbo
jasbo
