Question about Ovens
How do i change the light bulb inside my Technika B59VTIP oven?
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
Looking for a manual for a lofra 80cm freestanding oven model number LEF8GG3SS
Try contact Technika:
  • Sales
  • Phone: +61 (3) 9948 4577
  • Fax: +61 (3) 9948 4555
  • Email: sales@technika.com.au
  • Customer Care: 1800 649 969
  • Service
  • Phone: +61 (3) 9948 4545
  • Fax: +61 (3) 9948 4546
  • Email: service@technika.com.au
  • Customer Care: 1800 333 244
  • Spare Parts
  • Phone: +61 (3) 9948 4548
  • Email: spares@technika.com.au
Front Page Technika
Apr 07, 2015 | Ovens
Change oven light bulb?
Oven lights range from the ordinary household screw-in type lamp to ones inside a shatterproof enclosure. You may have to check with the manufacturer/distributor and/or an appliance parts supplier for specific information.
Jan 26, 2015 | Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
How do i change the light bulb in a Zanussi oven ?
Turn off at the wall and remove the light cover inside the oven by turning anticlockwise, this may be stiff, I use a well wrung out dishcloth.
You can see the bulb, which should be screwed out of its holder with care, also care when replacing. a I screwed mine in too hard and snapped the holder, but my oven is 5 years old.
Hope that helps
Jan 01, 2011 | Zanussi ZBF360 Electric Single Oven
How do I change the light bulb in the oven
You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
Apr 24, 2009 | Philips Ovens
Jenn-air microwave light bulb
This is an older (Mfgr. May, 1987) microwave oven. Functions perfectly, works an looks good to this day, just no light inside. I searched a couple of websites looking for parts for this unit and appliancepartspros.com provided schematics of the product that I own. From those drawings, it was determined that the microwave oven will have to be slid out of the cabinet above the built-in oven in order to change a $2.37, 40W light bulb. Just a handfull of scrws retaining the oven and exhaust baffles and I'll get it out (onmce the New Year's Eve hangover disappears). The engineer who designed a system like this must have been on an Acid Trip. I haven't looked closely at newer microwave ovens, but I'd have to believe changing a crummy light bulb would have to be made easier than this during the preliminary engineering phase of design.
Dec 31, 2008 | Ovens
Burned out bulb
you may have to rmove it from the back part of the oven. there should be access screws to allow you to change the bulb from the back
Dec 07, 2008 | Kenmore 47783 Electric Single Oven
Inside oven lights won't work.
Hey,
I went to the appliance store where I purchased the oven, and they called a Dacor representative. A flat end tool was given to me to pop out the plastic covers. There are no screws to fasten the covers, so you have to use this tool - which was not put in my kit at the time. Be careful when doing this, because the plastic cover can break. You replace the bulbs by pulling out and pushing in the socket. There is no turning the bulb. Handle the bulb with a paper towel, because the oil from your hands will take life from the bulb. Very important that the oven's breaker is off before this is done. Luckily, I had a very kind clerk helping me, and she even gave me the bulbs free of charge.
I like your website, and I will use it again in the future.
Feb 08, 2008 | Dacor ECS130 Epicure Electric Single Oven
big job belive it or not the oven will need to be pulled to change it please post your email and i will send you the manual
Jan 24, 2008 | Ovens
Ovens Logo
222 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
