Question about LG Refrigerators
I have LG refrigerator, ice maker dose not make ice. I have changed a new water filter,How to fix it?
  • 10,515 Answers
As long as the compartment is being supplied with the cold air then the ice maker has failed- replace it. There is NOTHING else it could be. Ice makers fail all the time, so there is no need to make a simple issue like this into something that you may think is way more involved. I only say this because many think that the ice maker lasts forever and never fails.I replace these weekly on service calls. Look on ebay for one at the cheapest price.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 08, 2011
My LG refrigerator has the ice maker hooked up to the hot water heater, is this right. MY HOT WATER HEATER HAS SLUDGE IN IT THAT IS GOING INTO THE ICE MAKER AND MAKING FOUL SMELLING AND TASTING ICE. ...
Having ice maker hooked up to hot water side is common practice...because the water is heated before it gets to be sent to the ice maker, it would have less air in the ice...kinda like a crude way to distill the water.
The sludge is from mineral deposits in your water...sometimes called hard water.
One of the best investments in areas of hard water is a water softener system, in-line water filters, or a combination of both.
Ya might look to see if there is a filter in the refrigerator to filter water before it gets to the ice maker as well.
Hope this helps...
Jul 24, 2011 | LG Refrigerators
My ice machine is not working ... I haven't changed my filter in 4.5 years ... Just purchased a filter today! Installed it ... should this fix the problem?
Make sure the on off switch is in the On position. If there is one it's a small white rocker switch on the ice maker. Make sure the wire bar is down, if there is one. if this dose not work you may have to change the water inlet solenoid on the back of the refrigerator.
May 06, 2011 | Frigidaire PLRS267ZAB Side by Side...
The ice maker dose not fill up with water.
Have you checked/changed your water filter? A bad water filter will stop/slow the flow of the water to your ice maker. Are you still able to get water from the dispenser? If you are, then it could be a bad ice maker, or the fill tube could be frozen, which is the main tube where the water comes in. This could also be a bad water valve inlet.
Mar 12, 2011 | Admiral 26 cu. ft. Side-By-Side...
The water dispenser is really slow coming out and it takes however to make ice. There is no kink in the water line to the fridge.
water stopped dispersing out of water dispense, No indication as to why. New filter was instlled, checked water line, no leakage indicated, ice maker had been making ice prior to this, turned off ice maker to avoid motor burn out.
Dec 26, 2010 | LG LRSC-26922 Side by Side Refrigerator
LG Refrigerator LFX24971ST - ice naker does not make ice
Arm should not be in up position unless harvest cycle is in progress. Or unless you manually put it there to cut off Ice Maker. Most likely ice maker is defective
Nov 12, 2017 | LG LFX25971ST Bottom Freezer French Door...
My Lg refrigerator ice maker won't work. The arm
ice is stuck in it, take it apart an clean it/defrost
Sep 07, 2009 | Refrigerators
No ice
IPour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 12, 2009 | LG LFX25960ST Stainless Steel French Door...
Fridgew/ice maker. ice tastes like sulfer.
This sound like you need a water filter change to the refrigerator.
Aug 05, 2009 | LG LFC20760ST Stainless Steel Bottom...
LG Side by Side - replaced filter now ice/ water will not worl
See if it works when you pull the filter out and try running it (without the filter in). If it works, try buying a new filter and make sure you have the filter that is made for your specific refrigerator. If no water comes out or no ice is made after pulling filter out, than you probably have a obstruction in the line. If thats the case you should have someone come out to fix it. If your mechanically inclined you can try to do it yourself. I would suggest reading the owners manual first, in the "troubleshooting" section.
Aug 05, 2009 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
46 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
