Question about Motorola Radio Communications
My motorola p040 has problem my channel tuner turns 360 degrees and yet it has only four channels to turn help me.
SOURCE: Xbox 360
Try turning the xbox on and pressing the TV/Video button on the tv or remote a few times and see if the picture comes up.
Posted on Sep 15, 2007
SOURCE: sanyo tv kit 360 ch fit in my old tv & lock channel kindly solve problem to unlock tv channel
i am imran
and i have also buy sanyo tv kit 360 ch fit in my old bpl 20"tv and i know for unlock tv channel.
try this this code definetly is solve your problem.
1st go to the locked channel.
and then press menu>system>child lock
and then press and hold down tv/av key and press swap key.
and see locked channel is unlock.
i have coming soon post for service code menu in short coming days.
please reply me to imr4@in.com
Posted on Sep 15, 2008
SOURCE: No color on HD channel while playing xbox 360
this is sometimes due to an improper organization of the component jacks in the tv input. it doesnt sound like thats the case considering it was working before, but you might want to take a second look and make sure your colour coded component jacks are in their corresponding inputs.
Posted on Oct 06, 2009
SOURCE: Can't view local HD with built-in QAM tuner on Sharp Aquos LED
I found this solution at ehow.com and it works: http://www.ehow.com/how_5417083_hd-channels-comcast.html. You'll just have to switch over to another input to view the HD channels.
Posted on Dec 07, 2009
milkburp
  • 416 Answers
SOURCE: no sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Posted on Mar 26, 2010
How do i get all the channels on the digital converter?
get a better antenna or aim your antenna in a different way,you wont get all available channels unless you have an antenna that can turn 360 degrees
Jul 13, 2015 | Televison & Video
Toshiba 40 inch not pickingup channels in scan
Tuner is ng. You can check out the repair cost but ......Another option is to buy an external HD tuner and feed that signal to your set via HDMI inputs. Cheaper than a repair.
Available on ebay eBayeBay
Sep 13, 2017 | Lands Phones
Channeling option/procedure
Wow, almost no information to help you. How new is the software? It could already be out of date because Motorola wants you upgrading about every six months. OEM cable? USB? Check your USB drivers. Using windows 7 or 8? Good luck with that! I always go back to XP to program. It works every time. Please re post what issue you actually have in detail.
Aug 10, 2013 | Motorola Cp200 Cp150 P040 Gp2000...
Have turned the tuner off and on and all iy says is that the channel will be available shortly. It has said that all day.
What cable provider? I believe providers such as comcast require either a set top box or DTA to work with a tuner.
Dec 23, 2012 | Arris Dct6416/2005 Hd Dual Tuner Cable...
Can not change channels by pushing channel numbers
Sounds like you don't have the tuner wired properly, IF you have a stand-alone tuner, then you need one wire to a continuous 12VDC for memory, the other 12VDC that's hot in accessory position, and then the ground. IF you hook the two 12volt wires together and they're only on when the car's on, then you will lose your memory of what channel it's on. Also, when you turn the radio off, turn it off with the BUTTON - not just by turning off the car. Give it a try using the radio's POWER BUTTON for on and off, NOT just the ignition, then it will remember the channel most of the time. Okay?
Jun 26, 2010 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Locked out of digital antenna in setup. I had it
1. ensure that you are on the TV tuner when you are trying to scan channels
2. if analog tuner works, but you cannot access digital tuner....the digital tuner is broken
When you turned channels before, did it switch between analog and digital channels seamlessly or did you need to press a button to acces digital channels seperately?
If you accesed digital channels seamlessly, #2 is not likely
If seperately, #2 is very likely.
Jul 10, 2009 | Sharp Televison & Video
RCA F27664 27" TV Problem: HELP
Intermittent loss of lower frequency channels ie Ch:36, higher channels ok
Dry joints in UHF tuner, resolder the PCB to casing earth connections inside tuner
Channel reception lost if tuner socket moved
Dry joints on IC522, IC521 and IC541 (located in the big heatsink about middle of the main pcb)
Nov 24, 2007 | RCA F27664 27" TV
Television stays on one channel
You likely have bad solder connections in the tuner.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Jul 12, 2007 | Sony KV-35V75 35" TV
Same channel on all channels
Yeppers it certanly sounds like the tuner control curcuit or the tuner itself is bad. With the back off the set and the tV on, if you tap on the side of the tuner does the set start to work? if so the tuner has to be replaced
Sep 25, 2006 | Sharp 32R-S50 32" TV
Radio Communications Logo
27 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
