Question about Samsung CLX-6210FX Laser Printer
Pink line on the bottom of the printed page - Samsung CLX-6210FX Laser Printer
  • 1,218 Answers
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Posted on Apr 08, 2011
Hi Everytning I print has a very narrow pink line straight down the centre of the page, also every so often the print has a black/yellow/blue/pink thick line running across the page. Thanks
The narrow pink line is coming from your magenta toner/drum cartridge. You may be able to open the from cover and look at the 4 toners. If you look at the magenta (like pink) cartridge, you might see the thin line on the drum surface.
The multicolored band that sometimes shows up on your prints is most likely the transfer belt unit. This is caused by an area of the belt that is not being cleaned very well. This probably tends to show up when you are running mutilple prints of a page.
So it looks like to may need to replace your magenta toner and look at getting a transfer belt unit.
May 13, 2010 | HP Color LaserJet 2600n Printer
Pink lines when I print on proper Canon photo paper
i'd say your print engine is quite out of sync...you had this canon for a while?
Mar 18, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Ricoh Aficio c3500 printing red lines accross the bottom of the page. This is an intermittent problem. Any ideas? Thanks.
If the lines are red the problem is with the transfer bel t/ cleaning unit.
If the lines are magennta( pink) problem is most likley the color pcu unit
or transfer unit
Good luck
;;Drew
Jan 04, 2010 | Ricoh Aficio CL3500N Laser Printer
My Xerox 6130 keeps printing vertical pink lines on pages
your color laser printer pink vertical line appear on the roller and film drum,
1) you need check the pink drum surface, it got damage if you find there is a different color vertival line on the drum surface, so you need change the pink drum.
2) check the pink drum cleaner (call brush to return the waste toner), it can not clean well sometimes, if the drum surface good.
Feb 06, 2009 | Xerox DocuColor 12 Printer
Printing not complete
you may check your ink cartridge
1) the cartridge some color almost empty, need to change a new one or refill the match color ink. test it and go next if not fixed
2) long time less using cause some color ink chanel(holes) dryer, you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 Hr, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Feb 06, 2009 | Lexmark X75 All-In-One InkJet Printer
Ricoh CL7000
Do a stop test using a document with CMYK content across whole document. Remove and examine M dev and drum and also check the master belt etc. The first component with the pink line on is most likely the faulty one.
Aug 20, 2008 | Ricoh Aficio AP3800C Laser Printer
A pink line is on every page printed
This is a very common problem with this model printer, it is caused by toner on the scanner mirrors. You need to clean the scanner assembly unfortunately it isn't very easy to dissemble the printer to get to it.
Aug 12, 2008 | HP Color LaserJet 2600n Printer
My HP Laser Jet (color) 1600 is printing color on pages with no color!!
the wastage part of ur pink toner is full a is dropping the powder on paper.get it cleaned to continue good printing.wish u success
Jun 04, 2008 | HP LaserJet 1600 Printer
Line Printing to hp office jet9110
I have this same problem, I have pink lines going through everything that I try to print in color. When I print in black and white, everything works fine. The blue and yellow ink cartridges aren't empty, so I'm not sure what the problem is. Any suggestions?
Feb 16, 2008 | HP Officejet 9110 All-In-One InkJet...
Samsung CLX-6210FX Laser Printer Logo
113 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
