Question about Kenmore 24 in. 15932 Built-in Dishwasher
Washer will not start up
Washer senses and fills with water, but will not start up. It will drain upon canceling as well, so I know it isn't a water pump issue. Any help would be greatly appreciated.
  • Anonymous Nov 16, 2008
    Dishwasher had been getting progressively louder over the last several weeks, but still cleaned dishes gret. Last week it stopped working in mid-cycle after getting very loud. Now when turned on, the dishwasher will sense, fill up with water ... and that's it. No spraying of water. It will drain the water when "cancel" is hit.
    We're at a loss. Any help is greatly appreciated.
    Problem Solver:
  • 13 Answers
Wash motor is jammed or loose wire connection.
Posted on Aug 20, 2008
Not finishing cycle
Is it draining out the water?? Dishwashers fill, spray, and drain more than several times during a cycle. After starting a cycle, let the unit fill, start spraying, and then cancel the cycle--listen for the drain pump activating and pumping out the water. If water is not being drained properly(within a certain time limit), the unit will error code out and stop. Also, make sure the filter is clear--if it gets clogged with "muck", enough water won't be sprayed onto the dishes properly, the pump will require too much energy to try to pump water, the control will sense this and shut down the unit to protect it.
Jul 25, 2015 | KitchenAid KDHE704DSS 24 6-Cycle/7-Option...
What to do about FH error on Whirlpool Duet washer?
unplug the washer to clear the board.turn on the water after one min. plug back in and try again
Sep 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My daughter has a new Whirlpool WTW4800XQ0, it takes the machine about 3 hours to go through the cycle. Okay this being said, when it gets to the spin cycle, it doesn't, she is having to pull the...
does it drain water, seems like it's gonna spin then starts filling up again? if this is what's happening it mean the washer is sensing that the load isn't balanced and it fill back up to move the clothes around and tries again, it will keep doing this untill it senses a balance of weight in the drum. if she tries moving the clothes around herself before it done draining she maybe able to keep it from doing this
Aug 05, 2011 | Whirlpool WTW4800XQ Washer
Sud--- what does that mean?
SUD-- means that the machine has detected too much soap during the wash cycle.
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
•If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
•Check the drain hose and make sure it is not plugged or kinked
•Check Wire Harness connections to the Drain Pump, Pressure Switch, and
Central Control Unit (CCU)
•Check/ Clean Drain Pump Filter of foreign objects
•Check Drain Pump
•Check the Pressure Switch
•Check CCU
Mar 28, 2011 | Kenmore Front Load Washer
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Apr 05, 2008 | Washing Machines
Washer won't fill
??????? sounds like perhaps you got your 2 hoses reversed when changing the pump assy
Apr 01, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 24 in. 15932 Built-in Dishwasher Logo
63 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
