Is AR5631 Sharp Copier contains a radiation? - Office Equipment & Supplies
  • 1,188 Answers
A fax machine is quite like a copy machine and we do here about this from time to time. The conclusions have always seemed to show no ill effects from using copiers and fax machines. Also, women who are pregnant are not warned of any harm.
Posted on Apr 08, 2011
MX m354u. What does error Code U2-91 indicate?
This seems a common error across a wide range of Sharp printers/copiers. It means
PCU PWB EEPROM CHECK SUM ERROR
See the following two links (for example)
Thread U2 91 on MX 5000N and SHARP MX M363N ERROR CODES Trouble Codes
If haven't got manuals or other documents which may contain helpful information they can be downloaded here. This link also contains contact information for sharp so that you might get support
MX M354N MXM354N Digital Copier Printer Sharp
6.November.2015
Feb 27, 2015 | Sharp Office Equipment & Supplies
Mx2700 replace waste collection container
You need to replace or dump the waste container. Flip down the main front cover on the front and you will see it
Jun 26, 2014 | Sharp MX-2300N Color Copier
How to replace used toner container
Open the front cover, push the green bottom and replace the container. Be careful, beware of the toner, hold the container up
Oct 23, 2013 | Sharp MX-2300N Color Copier
IS IT SAFE THE RADIATION OF SHARP AR-M35OU+
I am assuming you mean laser radiation from the laser unit that the copier uses to write the images on the drum. if correct, normally when front door cover is open the laser unit is disabled and no laser radiation is present and therefore it is safe.
Dec 18, 2009 | Sharp AR-M350U Copier
Changing toner cartridge on copier
Open up the large front door, it will swing downwards. At the top section you'll see four boxes with front handles. Each of the boxes is a slide-out container of toner.
Follow the instructions on the new toner box to prepare it for the copier.
You'll note each toner box has a color designation (on a plastic label just above where you grab). Simply grab the handle on the one you need to replace, pull it out and then slide in a new one.
Also note there are four colors: Yellow, Magenta, Cyan and Black. The LCD screen should indicate which toner bottle(s) to replace.
Aug 30, 2009 | Sharp MX-2300N Color Copier
F9-00 (Print Function) Error Code on Sharp AR-287
this copier will display f9-00 if the nework is not connected or the card is bad this means network connection lost usaally resting copier will work if the network is on if not call service
Mar 03, 2009 | Sharp AR-235 Copier
Firmware upgrade
What version do you have now?
Here is the newest version posted on SharpNet:
Version H2.40 contains the following modifications: 1. H5-01 error detection changed from 3 successive errors to 5. (POD1) 2. “H3” errors eliminated when ICU detects E7-00 error.(PCU processing change) 3. Image rotate information retained during paper-out condition by specifying use of manual feed tray. 4. If L3-00 or L1-00 errors occur after upgrade, TC 26-59 settings must be changed. Refer to technical bulletin AR-337-001 R for instructions. AR507.EXE Contains all the files needed to upgrade the AR287/AR337 copiers using a PC, SCSI adapter, and 7 series Black & White Imager. (AR287 ~ AR507) Refer to Technical Bulletin AR-505-001. AR507.EXE contains the following files – ICU_H2_40.mot, ICU_H2_40.fd, PCU_H2_40.mot, PCU_H2_40.fd, OPE_H2_40.mot, OPE_H2_40.fd, and Flash5.1.exe
The firmware upgrade on these "toner bombs" is no walk in the park but I can walk you through it and provide the bin files and software. contact me at double-u double-udouble-u dot brianbell dot net for more information.
Dec 26, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-C160 Color Copier Problem
hi im jules_09.its easy just remove the collecting container it must be full with waste toner then just disposse of the waste toner.just open the front door then locate the container its just ther you cant miss it.its a plastic bottle sometimes at the side of the machinre,
Oct 11, 2007 | Sharp AR-C160 Color Copier
Open Questions:
173 people viewed this question
k24674
