Question about Lexmark Office Equipment & Supplies
Lexmark x4650 WiFi printer, for some reason when the printer is on it takes contorl of the wireless network and disables internet connection. But, wireless printing works fine..... then.... to get the internet working again, i have to turn off the printer and reset the router....... HELP ME, what do i need to do for it to all work in harmony???!???!??!??
  • michael1984 Aug 07, 2008
    Hello???? any techs out there???? or is this site fake??
  • michael1984 Aug 08, 2008
    .... the computer is not joining the printer network.... it has been added to the wireless internet network, so that any computer that joins the network with the appropriate software can wireless print aswell as surf the net... this is why i am confused......
    ..... Next solution please....
Your computer sounds like it is joining the network that the printer is broadcasting
Posted on Aug 07, 2008
How to stop orange wi fi light from blinking
The blinking WiFi light on your printer could indicate that it's trying to communicate with your wireless network or it's not connected to your wireless network anymore. A quick fix to this problem can be achieved by rebooting your system. Simply unplug and re-plug your printer and your wireless router into the power outlet and reboot your computer. Once everything turns back on, check the status of the WiFi light and try to print again to verify that the problem is fixed.
You can also do the following steps to reset the printer wireless network adapter:1. From the printer operator panel, press the Setup button.2. Select Network Setup.3. Select Reset Network Adapter.4. Hit the OK button.
The WiFi light will momentarily turn off and then on solid orange. You can then try to reconfigure the printer to connect to wireless network using the Lexmark Wireless Setup Utility application on your computer. Go to Start menu > Programs > Lexmark 4600 Series folder > Lexmark Wireless Setup Utility. Simply follow the instructions on your computer screen.
However, if you wish to have it connected directly to your computer. Simply connect the printer with the USB cable that came with it in the package.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 20, 2011 | Lexmark X4650 All-In-One InkJet Printer
My wi fi orange light is blinking on my lexmark x4650 printer
The blinking WiFi light on your printer indicates either your printer is trying to communicate with your wireless network or your printer is not connected at all. For a quick fix, try to disconnect your printer from the power outlet. Power cycle your router and reboot your computer. Then, power on your router first, then your printer and lastly your computer. Check the WiFi light on your printer. If it goes to a solid green, that means you are connected back in your network. If not, you may reset your printer's wireless network adapter to its default settings. From the printer operator panel, press the Setup button > Network Setup > Reset Network Adapter to Default. The WiFi light on your printer will momentarily turn off then back on solid orange. Then try to run the Lexmark Wireless Setup Utility on your computer to reconfigure your printer to connect to your wireless network.
I hope this helps.
How to stop wi fi from flashing orange on my x4650 lexmark printer
I hope this helps.
Nov 20, 2011 | Lexmark X4650 InkJet Printer
My printer is connected to another wireless network which is not the same as my laptop how do i connect it to the right one?
I`ll guess You`ll have to connect your PC to the printer with the use of a usb cable.
Then run the Lexmark software (Lexmark printer home) or similar (don`t know what you are using?)... Go to "settings"; and choose wireless setup utility. You`ll have to manually set the SSID (the wanted wireless network) and the WIFI password for this network. Hope this will help.
May 23, 2011 | Lexmark X4650 InkJet Printer
I am attempting to scan a document with my X4650 without success. The copy function works with no problems. I have used the scan function to my computer on numerous previous occassions without problems.
How is your printer connected to your computer, wireless or hardwired with a USB cable? If wireless, check the status of the WiFi light on the printer (green = connected to a network, orange = not connected to a network). Try to turn off/on your printer. Doing this usually fixes minor communication issues. This article in the Lexmark website might also help resolve your scan problem: No Communications Error When Trying to Print or Scan.
Apr 18, 2011 | Lexmark X4650 InkJet Printer
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
I intalled windows 7 64 bit on my laptop and when I try to download the drivers from Lexmark, the printer isn't available. I also can't connect through wireless. Can you help me?
What is the status of the wifi light on the printer? orange or green? blinking or steady? For the Lexmark X4650 Windows 7 64-bit driver, click on this link Lexmark X4650 driver for Windows 7 64-bit. Download, execute the file and follow the instructions on the software. Thanks.
Jan 03, 2011 | Lexmark X4650 InkJet Printer
Ive recently changed the password on my wireless network and now my printer keeps flashing orange which means it wont connect to the wireless. From reading a similar post i saw you recommeded to reset the...
To reset the printer's wireless network adapter:
  1. Press Setup(wrench icon).
  2. Go to Network Setup, press OK.
  3. Go to Reset Network Adapter, press OK.
WiFi light will temporarily turn off then will turn on solid orange. Now, run the printer's Wireless Setup Utility on your computer to configure the printer with the new wireless settings. You will need the USB cable temporarily to successfully configure the printer. Thank you for choosing Lexmark.
Sep 10, 2010 | Lexmark X4650 InkJet Printer
My Lexmark X4650's wifi light is off. I have tried to reset the wireless settings but when I try it says "network connection in progress" and goes back to the set up menu. How do i resolve this? Thanks.
Great job on trying to reset the printer's wireless network adapter. Somehow, the printer's memory is stuck to thinking to connect to a wireless network when it's not communicating at all. Unplug the power adapter from the printer. The power adapter is the rectangular black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging back the power adapter in the printer. That should refresh itself. If wifi light won't turn on orange after the printer's on ready, reset the wireless network adapter again. Thanks.
Jul 24, 2010 | Lexmark X4650 InkJet Printer
How do i reset my wireless printer? i cannot reconnect to it seems the printer cannot connect to the wifi network
Here's an article found in the Lexmark website on How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults. Just click on this link: http://bit.ly/aePRSr. Follow the instructions carefully. Hope this helps.
Jun 21, 2010 | Lexmark X4650 InkJet Printer
220 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
