Question about Sharp Televison & Video
I have just purchassed a Sharp LC46LE820X. I have just noticed after 5 weeks three cracks in the screen directly from the bottom edge running upwards from the where the panel is fixed to the stand. Sharp's service agents have told me that this is not covered under warranty. They were not there when we purchase the set, and they are certainly not the result of any impact damage to the panel. Do you have any advice whether this has been found before or any avenue I may have to get it repaired by Sharp?
  • 77 Answers
SOURCE: screen is broken, is it worth fixing
It is not worth repairing, the panel would cost as much as a new tv. have it looked at though maybe your warranty tech will slide it through. Probably not but its worth a look.
Posted on May 11, 2007
  • 103 Answers
SOURCE: Sharp 42" flat screen LCD T.V.
You have a bad buffer ic,which is part of the lcd panel.Definiately call sharp to get it repaired.If it doesn't have a warranty,persistence through sharp will get you results.
Posted on Mar 07, 2008
DRACO A5OG
  • 22 Answers
SOURCE: Blue transparent line on new LG tv
If it's new you should be under warranty.
If not, you need to replace the Power Control Board 6871qch038a
My Plasma is a VIZIO P42HD but all the components are LG.
Spoke with PartStore.com, rep stated 6871QCH038C (038C) is the superceded replacement for the defective prone OEM 6871QCH038A (038A). They and others offer the 6781QCH060Q (060Q) for $50 - $100 more. I opted for the 038C, but I was concerned about the title of the part which states "HAND INSERT"... PartStore.com rep stated it is in fact a board and there is no soldering needed, just "plug and play". DONE, paid only $120.95 + next day shipping for $29.95.
Since I took the TV apart before, it was a breeze and took about 2 hours, start to finish.
Important note, remember to remove the two 1" square spunge type heat sinks/pads the new board needs those for a proper installation and protection of the certain component.
Also you need two small zip ties to replace the ones you are going to clip off.
Added Bonus, the new board fixed other issues:
1. At times I would get a squeegly red line go across the screen. I thought it was the source (cable) but it is gone now.
2. Screen Shift, when I use the XBox for Games or DVD/HDVD the screen would shift. Very annoying, prior to swap out, recently the screen started to shift watching cable. Now it is no-longer an issue.
I am really pleased with my DIY repair and wanted to share.
The damn Vizio Out of Warranty Service wanted $360 for a service call which included the part for $125 plus they take my bad board for exchange.
6871QCH038C $120.95 http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenit h/6871QCH038C/New.aspx
Over Night Shipping #29.95
Posted on Dec 31, 2008
  • 8457 Answers
SOURCE: large LCD cracked screen from impact, worth repair?
Cost alot to replace LCD screen not worth the money.If u can find it on Ebay bad PCB,and a
good LCD screen is might worth to repair.
Posted on Aug 23, 2009
Testimonial: "thanx for fast and easy to understand answer!"
SOURCE: Flat panel tv repair
I don't think the repair is going go be cost effective.
If you have a rider or service coverage on your home owners insurance or vehicle comprehensive insureance you may be able to get some replacement cost covered. Possibly worth checking out
Posted on Mar 18, 2010
My screen is reversed. You have to touch the opposite side of the tablet to select what you want and I just want to know how to fix that.
Here are suggestions I found online:
Press the "font size" key. It should look like Aa or some similar marking. When you click that, you should be able to change the orientation. Use the 5 way controller to move the "selection" up and down and left and right. and then press it when you are over the desired rotation. You want to select the very first A selection
Mar 03, 2015 | Tablets & eReaders
This could be 1 of three things! 1-main lcd panel
2-y sustain module
3-z sustain module
This is something you cannot do yourself my friend.
Feb 22, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Sharp EL-2196BL
mechanism.
Sony LCD tv
i guess its the old magnet problem maybe in fluke u or someone in your house had taken a magnet around your tv try fixing it with a magnet by moving the magnet again around the screen and using the same old technique by moving the magnet slowly on the defected area and then quickly taking it off
Nov 05, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
6600 face plates
actually thiers an opening tool for that, but we can improvise it. find an unused credit card, pvc ID or the like. use its edge to open it. insert the edge of the card to the bottom edge of the casing in an upward direction and slowly rotate it card in a clockwise direction gradually until you hear snapping sound. continue rotating it until you reach at the other edge...
hope you open it...
Oct 20, 2007 | Nokia 6600
Blackjack with "E" icon on screen, what is this?
The 'E' comes up when are in your home network(not roaming) and an 'R' comes up when you are roaming(logged on to a different n/w other than your providers but has tie up wit ur network provider)
Jun 07, 2007 | Samsung Blackjack SGH-I607 Smartphone
Televison & Video Logo
52 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
