Tv / dvd combi , since moving house the dvd will not read any disc and sounds as if it is sticking making a clicking sound and then no disc read error sign
  • emu 33 Aug 06, 2008
    Thanks for that. I was hoping there would be something less obvious you could tell me!!! Any way best buy another dvd! Cheers for the quick response. x
    Champion:
  • 232 Answers
The player probably was damage durning the moving process.
Posted on Aug 06, 2008
Rosen roof dvd player has sound but no picture please help
Hi Gill.
Check, Make sure the cables are connected. Try cleaning the laser and the DVD. Make sure the TV is on the correct input.
try swapping one of the sound cables to see if the yellow cables is in fact damaged.
1) Plug the DVD player in to the TV that it does work on. Make sure there is no disc in the player. Check the DVD players set up menu. Look in the Picture menu and change the output to "RGB" Move the player back to the TV/VHS Combi. Select the input that gives you RGB1.
2) Same as above, but this time change the Picture menu to PAL (or composite or Video....whatever is the other option name that isn't RGB or S-Video). Retest on the Combi, but this time you want AV1.
If these don't work then you might need to have a look in the TV manual about connecting external sources. It could be that because the combi has a recorder that it's trying to stop you from copying DVD to VHS. See if there's an input on the combi that bypases the recorder.
Read more: https://www.diynot.com/diy/threads/dvd-problem-sound-but-no-picture.211588/#ixzz5FYrJiX6o
I found all this on the internet so not sure if it will help you out.
or try this link.
dvd player has sound but no picture Google Search
May 15, 2018 | Rosen Car Audio & Video
My dvd combi is saying invalid disc and sounds like its spinning but then makes a clicking noise
Make sure the disk you put in the player is compatible with what is in the manual. Don't try to use disks you burned yourself when the manual does not say it is compatible with CD R or DVD R + or -
And when it is compatible with CD / DVD R, put the files on the disk in a format the player can read. Don't try to play MP4 disks, because almost no MP4 format is compatible with w DVD player.
Jan 14, 2015 | Televison & Video
I have dvd tv combi and the sound will not go above 30. I have tried going into settings and the volume but nothing happens.
follow this steps and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Oct 25, 2013 | Televison & Video
No sound from pre-recorded dvds in tv/dvd combo
Check the sound setup to TV. Refer its user manual for details. Check whether the audio format to the recorded disc do match with to that of TVs.
Apr 25, 2013 | Televison & Video
Will not play dvd.- it says to check disk. On starting, the dvd chamber clicks multiple times, then it says to check disc, then it turns itself off. Thank you.
Hi
Try using a DVD/CD laser cleaning disc.It sounds like it's having trouble reading it.
Saying that with a lot of combi units sometimes the DVD drive fails down to using cheaper components to keep the price low.I guess that's the price you pay for buying two units in one.
Try cleaning the lens first though.
Good luck....
Nov 14, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Put dvd in and it makes clicking noise and doesn't detect it.
The Clicking sound happens, when the lens which reads the cd's,dvd's move off from its original position, this happens when the particular equipment is moved or pushed. In some rare cases, when you insert a very scratched cd, dvd. This can be solved by the particular tv company technicians, or else your warranty will be void.
Try checking whether the lens works perfectly, by playing different kinds of content ( audio cd, mp3, dvd ) etc... If any works, then your lens is working perfect. Later, try cleaning the lens using the " cd lens cleaner kit ". It will be available in any computer accessories related shop.
Thank You.
Jun 17, 2010 | Polaroid TDX-01930B 19 in. LCD HDTV
When I record on DVD +RW disc from my other Tv and try to play it on my combie tv ,it will only play if my disc is finalised. so if I only record 30 mins and have to finalise ,I am wasting the disc. Why...
Some tv's are not capeable of reading Rewritable disks. By finalising the disk you are basically making it a non re-writable and thus allowing your other tv to read it.
Jul 16, 2009 | Televison & Video
I have combi tv/dvd player. the dvd is noisy when disc is put in
hi..the reason to this problem is your belt.
once you replace the belt you wont get such
type of sounds.Replace the old belt with the
new one.This will solve the issue.
check this out..
thank u..
rate me..
Feb 22, 2009 | GE Televison & Video
Combi not playing DVD's
If this unit is a few months old can you swap it with the shop you got it in? Errors like the ones you mention sound like the laser is not reading the DVDs. (Which you would expect to find on old players).
Just check you are putting in valid DVD's which play in other players and that you are putting them in the correct way (not upside down - yes it happens).
Regards
Mar 31, 2008 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
