Question about Acer X1230 DLP Projector
Getting 'No signal ' response. What could be the reason?
  • 442 Answers
Try using a lower screen resolution on your PC,
Try checking that the signal you are sending to the projector is actually there
Posted on Apr 08, 2011
I have two tv's hooked up to an antenna. Was getting 20 some channels on both. Now one of the tv is only getting 3 channels. What could be the problem? I did a scan. .??
Chances are your not getting a strong enough signal for some reason and only the stronger signals are picked up on a scan
Oct 29, 2017 | Televison & Video
Www nokia repair com
simply getting old, the phone wasn't designed to pick up the new signals
Apr 21, 2014 | Nokia 2690 Cell Phone
I am using samsung corby pro mobile in Dalian,China. So here I am using China unicom sim card but GPS is not getting connected here. The officials of China unicom are saying that its the Work need to be...
Yes, that seems true. Telephone companies are more or less not responsible for GPS signals, unless they're using assisted GPS (aka A-GPS or something like that) which means that they're using the cell signals to help determine your position. Maybe your phone has problems getting GPS signals.
Mar 05, 2011 | Cell Phones
Check engine light code P1278
CODE P1278- HEATED OXYGEN SENSOR 1 SLOW RESPONSE.POSSIBLE CAUSE EXHAUST LEAK AT EXHAUST MANIFOLD OR PIPES.FAULTY PRESSURE REGULATOR LEAKING OR FUEL INJECTORS LEAKING.AND FAULTY TPS SENSOR.
Jul 08, 2010 | 2004 Nissan Sentra
My phone not getting signal properly when a signal low area.some time even is signal available,cant take call to phone.
thats a hardware problem, your RF amplifier should be weak. it is responsible for amplifying and mentaining the signal on your phone. you should therefore take it to a service point so that they check it anf if possible replace it.
Regards
May 10, 2010 | Nokia 6300 Cellular Phone
I am not getting power to the coils
on the right side of the bike remove the bolts round housing inside is your ignition plate change the plate it is responsible for sending a impulse signal to the coils to fire, make sure the voltage signal is being sent if not change if it is sending the signal the coils at bad.
Mar 07, 2010 | 2002 Suzuki GSX 750 F (Katana)
SLOW RESPONSE TIME WHEN TRYING TO PRINT
Hi !!
Laser printer are usually fast but if you are getting slow response try to clear cache. Bocz computer holds print in memory so it can be one of the reason and i'll be able to answer in more detail if you'll send me complete configuration of your computer along with any error if you are getting while printing and also let me know is it just with printing or overall your computer is slow.
Thanks,
Hope that helps
Jul 09, 2009 | Dell 1720dn Laser Printer
My turn signals and hazard are not working
you need to check flashers and fuses thery are under the dash and in the engine compartment/Please rate my response thank you very mcuh
Jan 29, 2009 | 1991 Mercedes-Benz E-Class
I'm not getting video neither keyboard
Nothing less than a 600 watt power supply for the reason PCI-16 video cards need more power .
Jul 30, 2008 | EliteGroup NFORCE 570 SLIT-A Motherboard
GETTING COM AS 634 INSTEAD OF OK STATUS WHAT IS THE REASON
This is what the code means:
Redial was not successful due to no response from the called station or wrong number dialed.
Note
: If busy tone was not detected, the machine will only redial once.
So the your fax machine is getting no response from the fax you're calling.
Hope that helps...
Jun 13, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Acer X1230 DLP Projector Logo
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
