Question about Kitchen Ranges
I have a Craftsman garage door opener Model #139.53664SRT that has worked great until recently. When I leave my garage & try to use the keypad or remote after opening the garage door from the inside of my garage, it will not allow me to unless I first turn off the opener lights & step over the sensors without turning the lights back on. Is this opener fixable or do I need to buy a new one? Also my car no longer will open the opener period..
  • Kitchen Ranges Master
  • 822 Answers
From the description about the lights which does have a slight affect on their sensitivity suggests the sensor adjustment. The sensors that detects obstructions appear to be out of adjustment.
Check the alignment for proper operation. It may be dust that is obstruction the sensor.
i have a Craftsman garage - garage door safety-dmbde0w01a5yu2mfdv43xlfn-4-0.jpg
hope this helps http://www.searspartsdirect.com/partsdirect/user-manuals/13953975srt1-craftsman-parts-manual
Posted on Jun 23, 2017
SOURCE: Oven door won't open
Best bet on this one is to replace the lock assembly. Although you could make a minor adjustment that may help. what you would do is with the door open put latch in lock position and then slightly bend latch to the left, making sure not to twist it. This works about 80% of the time.
Posted on Aug 12, 2007
SOURCE: Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Posted on May 25, 2009
  • 2602 Answers
SOURCE: oven wont light unless you turn on a stove eye and
did you slove the noise from the oven
Posted on Jan 13, 2010
  • 2468 Answers
SOURCE: Garage door closes then goes up immediately has
there are limit switches on both the up and down positions,you need to adjust the travel on these per mfrs directions
Posted on Jun 07, 2010
woobie dog
  • 1273 Answers
SOURCE: Hello! I have a
Hi, W/D here.
Check the eyes, located at ankle height on either side of the door and compare them to the other door.
Sometimes, they are being occluded, where the light cannot be received by the receptor. If this is the case, move whatever is in the way.
The lenses can get too dusty to be effective. You can wipe them with a soft cloth.
The wires that are connecting the light and receptor to the control can touch. For whatever reason, they are usually just twisted together, and not insulated. The fix is to separate them.
They can be bumped out of alignment, where the receptor side isn't "seeing" the light from the source. They can be checked and realigned with a string line, or just by aiming them by hand to check for any difference in the lights before making any permanent fixes.
Lastly, they can just wear out, and have to be replaced. The set can be purchased from Lowe's, etc. as a generic replacement, from Sears or on-line.
Hope that this helped, --W/D--
Posted on Feb 06, 2011
How do I check a wireless garage door keypad, to see if it is transmitting?
These remotes don't loose the programming code when a battery goes dead, most likely the remote or the board on the opener went bad, do any other remotes work? You can take the remote to an auto parts store and test it there. (They have a tester for key fobs)
Sep 24, 2014 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman Model # 139.53664SRT that has worked great until recently. When I try to close the garage door by keypad or with remote, it will not allow me to do so unless I turn the light out once...
The first thing I would do is remove the light bulb from the socket and try the opener. I have a feeling the bulb itself is bad or there is some arcing in the socket. Try unplugging the opener and prying out on the center connector of the socket.
Apr 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
When I leave the garage, I can use the keypad to close the door.......but when I return and try to open the door with the keypad....it won't open.
Make sure the battery is good. A weak battery can cause this problem. If that is not the case and your other remote units work your keypad may be going bad and need to be replaced.
Dec 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
Cant get wireless Keypad to Link to new Garage Door Opener
The radio frequency has changed and the old keypad will not work with the new opener.
Mar 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming kepad for Sears Craftsman Garagedoor opener 1/2 hp
The only procedure I have ever followed is to press the learn button and then enter the code, and not do anything else. I think your last step of holding the button until the light goes out is clearing codes as fast as you enter them. Just stop after you enter your code and let the learn mode time out on its own. That should do it.
And don't put your head through the wall. It just causes more headaches.
Feb 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Clicker garage door keypad works inconsistently
no relation. did you plug rpm sensor and logic board connectors on well.
Dec 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door keypad & remote
You need to sync both. I have a LiftMaster. If you want to change the code on your keypad you need to open up the garage door motor compartment where the light is (mine is in the back). Press the learn button, within 30 seconds enter the new code on your keypad and hold down the enter button for several seconds until the light on the opener blinks to tell you it has learned the code. Test the new code to see if it works. If the new keypad code works, then try the remote. My remote will not work after I reprogram the keypad. If the remote does not work (check battery) then climb back up the ladder and press the learn button on the garage door motor again, press the remote button and hold down until the light blinks again and the opener has learned the new code. This process works when I need to sync my remote and keypad. Good luck, I hope this helps.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
