I'm tring to disassemble a hp 4220 notebook i've got all the screws out of the bottom panal it'sall lose aound the outside but their has to be two screws in the center and I can't find them. I either need the maneul or someone that can tell me how to get them out.
    Sergeant:
    Champion:
  • 217 Answers
Here is the manual. Click here. Did you check inside the memory compartment? Under the keyboard? I am not sure which stage of removal you are on but you can see all screw placements in this manual.
Posted on Apr 08, 2011
Disassemble an HP dv7
You didn't say why, but this site will get you started: http://www.insidemylaptop.com/disassemble-hp-pavilion-dv7-notebook/
GOOD LUCK mind all those tiny screws!
Nov 19, 2012 | HEWLETT-PACKARD HP Pavilion DV71451NR...
1999 Chevrolet Silverado power windows, How do you remove drivers side door panel
not really sure on that one but on most first you will need to remove screw around handle that opens the door that needs to be removed. also should be screws underneth handle that pulls door shut that you will have to remove and in some cases . check around edge of door panal for more screws and if found remove them also. once all screws are removed you will need to pry on door panal slightly because there are clips behind panal holding it on. in alot of cases the clips break when removing panal but dont worry the can be bought at your local auto parts store and are very easy to replace. I usually use something flat like a small stiff putty knife to help pry door panal lose. this helps insure that you dont break of crack the panal. after all clips are off simply unplug wire connections and door handle linkage and your done. .....hope this helps and good luck
Aug 13, 2012 | 1999 Chevrolet Silverado 1500
Locate CMOS battery Lenovo Y570
It should be on your motherboard. You have to carefully disassemble you lap top .. Removing all Usb,Battery, and external connections.
U need a small screw driver to take it apart.
Leave your computer on for a day. If your need specifics let me know!
May 07, 2012 | Lenovo IdeaPad Y510 Notebook
I want to remove hard drive on a k40ij-d2 notebook
unscrew 4 screws on the back.<br /> remove battery cover, remove one screw there too.<br /> slide the bottom panal forward.<!-- from fixya rte -->
Aug 16, 2010 | ASUS K40 Notebook
How to replace a window on a 2002 saturn sl2 with power windows. i cant get the door handle assembly off
As per the Haynes manual for your vehicle.
DOOR WINDOW GLASS-REMOVAL AND INSTALLATION:
1. Remove the door outer panal.
2. Lower the window glass.
3. remove the two nuts and one screw securing the glass.
4. Remove the glass by lifting it up carefully and rotating it inward.
5. Installation is reversal of removal.
DOOR OUTER PANAL-REMOVAL AND INSTALLATION:
1. Remove door trim panal.
2. Remove the outside mirror. Remove the foam block from the mirror opening.
3. Remove the outside door handle.
4. Open the door and pry thhe outer sealing strip out of the window glass opening.
5. remove the door panal screws.
6. Detach the front and rear of the outer panel, then lift it toward the rear to remove it.
7. Installation is the reverse of the removal procedure. Apply thread locking compound to the panel retaining screws.
OUTSIDE DOOR HANDLE-REMOVAL:
1. Pull handle out and puch the centers of the retaining pins through the pins, then remove them and detach handle. (These pins are located underneath the handle.
Hope this helps, let me know if you need any other help.
Feb 06, 2010 | 2002 Saturn L-Series
How do you dimantle cabinet to access heating element and safety therm? dle5955
unplug the dryer,remove the three screws at the bottom panal,remove panal and the element is on the right.the safety themastate is on left side on outside of body of heating element.
Sep 30, 2009 | LG DLE5955 Dryer
How do i separate the top part from the bottom part of my laptop. I want to buy another motherboard, but I'm not sure I can do this stuff myself
I don't think you can, maybe you can separate it but how you sure that when you buy a new motherboard is working. Or maybe you can buy the exact design of motherboard is how you back back in. Even user manuals are not put to know how to disassemble the laptop. Only Certified Technician can do that my friend.
Just bring to your nearest HP Computer Center to let them provide all of it, at least you have warranty whatever problems occur again.
Hope this tip might help you.
Sep 23, 2009 | HP Pavilion dv1000 Notebook
Hp photosmart m425 flash no longer works
I would look to see if wires are pinched going to the flasher.
You have disassemble the camera.
I would think first before tring this.
Remove 3 screws on bottom, 1 in battery compartment, and 1 at very top of usb flap (look good).
Now slide the side piece starting at the usb flap then apply pressure to top and away from unit.
now look for 1 silver and three black screws (facing back and front, look good).
Remember to replace battery door first if it fell off during process.
*TEST NOTE: You can place batteries in and place a penny across the bottom to test before you put it back together.
Dec 30, 2007 | HP Photosmart M425 Digital Camera
Display Screen is White
I would check the wires connented to the display screen. they run from the bottom to the screen.
See the screen look at the bottom follow the wires to the connector on the very bottom and check that. Remember to replace battery door first if it fell off during process.
Dec 23, 2007 | HP Photosmart M425 Digital Camera
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
