Hi Have an 86.1 error code on my HPz6100 how do I fix the problem?
Fix error code e95
bad recirculation pump or temp sensor
Aug 27, 2016 | Pool & Spa
Hp designjet t1200 error code 80
80 ......... there is more to error code than just 80 please give full error code details for a useable solution .
eg 86:01 ( carriage motor transport error)
or 0c00340a is also a fault code
if you can supplye either full error code then I will attempt to help you resolve it thanks
Oct 07, 2013 | HP DesignJet Office Equipment & Supplies
When i was replace the trailing cable my plotter writing the system error:86:01 how to solve
86:01 fatal error code resetable with power cycle- error is down to encoder not reading/ blockage on media path - encoder strip missing
1. clean and clear accuride rails ( long silver bar )
2. Clean or replace encoder strip
3. clean or replace encoder sensor
if all else fails contact Belmonte.co.uk for fast response
Jan 02, 2013 | HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB...
I have a HP Z6100, and I got many times error 86:01 possible paperjam, after changing encoder strip and encoder sensor, carriage PCB. I still have 86:01 error, after Scan Axis in maintenance mode, the...
Observe when 86:10 error appearing? after intializing the carriage or immediately after powering on?
# If immediately error appearing do the below discussed activity
# after intializing if error appearing check trailing cable,service station wipers & cappings,cutter position, cutter movement & lubrication on rail.
Detatch power cable & data cable,remove right door, pull out carriage assembly from service station area (if its locked by service station manually unlock it). Remove cable connections, screws & take out service station from the printer.Place the service station out side(ensure that cables has to fix properly) connect the cables,switch on the machine, check for the error..
if error is not appearing: check the service station, found any damage replace it or shoot the problem.fix it back..
*even error is appearing: Remove carriage belt from the pully..check carriage movement, if found any hardness/obstruction? shoot the problem.
Finaly: check trailing cable( while carraige movement some tracks may lose their continuty)
Power supply.. ( check voltages)
Need your feedback for further help.. vinay229229@yahoo.co.in
Apr 11, 2012 | HP Designjet Z6100ps InkJet Printer
Hi i need a radio code for Mercedes Benz Model No: CM2299 Serial NO: A 208 820 05 86
Hi i need a radio code for Mercedes Benz Model No: CM2299 Serial NO: A 208 820 05 86..but i dont know germeany lenguage ad plz tell me it english language
Feb 15, 2011 | Alpine Car Audio & Video
How do you fix a F 86 error code on a konica 3135 copier?
This error code not exist .Please tell me precise your problems and your error code.
Dec 02, 2009 | Konica Minolta Office Equipment & Supplies
Error code 86
If this error code appeared but was NOT caused by a paper jam, then
try the following:
 Too much friction in the Slider Rod. Enter the Printer Information
utility (⇒ Page 4-27) and check the Scan-Axis usage. If the
percentage is close to 100%, then lubricate the Slider Rod.
 The Carriage is bumping into the Service Station. If the carriage
is stuck at the right hand side of the Printer and cannot be moved
out to the center of the Print Platen it is because the Service
Station cannot uncap the Printheads. In this case replace the
Service Station/Aerosol Fan Assembly
Dec 24, 2007 | Microsoft Windows Vista Ultimate Edition
Error code "85" or "86"
Olympus customer support will know the answer. There are so may variables it is not possible to list them.
Sep 04, 2005 | Olympus Camedia C-960 Zoom Digital Camera
205 people viewed this question
k24674
jasbo
jasbo
