Question about HP ScanJet 2300C Flatbed Scanner
Failed to initialize the device - HP ScanJet 2300C Flatbed Scanner
I purchased a seagate expansion 1tb in 3.5". initially when i plugged it into an usb port,(LED lit) it doesn't recognized by my Vista home premium 64-bit. i plugged it and waited for several...
> I purchased
Brand-new, I presume?
> is it a failed HDD
Yes. Take it back to where you purchased it, and get them to replace it, under warranty.
> software problem
No. It shows-up in "disk-management" as a recognized, but not-yet-initialized, device.
Thus, all the software to support it has been correctly loaded.
Exercise the warranty.
Feb 17, 2011 | Seagate Expansion 1 TB USB 2.0 Portable...
My bb bold 9700 cant access instant messaging , its been pending for 4 days
Remove the back cover, then battery. Wait for 2mins, replace battery and back cover.
If the above fails, your will need to register your device to the BIS again.
Use the following link:
My blackberry initialization failed
Hope this helps!!
Tell next time, take care of your blackberry device.
Feb 07, 2010 | RIM BlackBerry Pearl 8100 Smartphone
Where can i get free updates for initial 510 gps
try to consider to update by around $40 as minimum if failed to get free updates and have fine
Dec 16, 2009 | Initial GM-351 GPS Receiver
My wireless connection has gone down - internet connection is fine, AOL say I need to turn my wireless connector on but I didn't do it initially and don't know how to do it - help pls!
try a system restore first to the date when laptop was working fine with the wireless. if fails then uninstall then reinstall the wireless driver. if fails check if the wireless device still detected in the device manager. if fails then reseat the wireless card.
if you are using a wireless device thru usb then make sure the usb ports can read other usb devices just to isolate the case. if fails then do a clean installation.
Oct 21, 2009 | Computers & Internet
Dryer timer not working on a kenmore dryer model 80 serious
HI, if this device isn't working, you will need to replace it. it cannot be repaired. it is designed to fail and when it fails, you will have to replace the entire timer control module.
This device control all aspects of the cycle you initiate.
May 23, 2009 | Kenmore Dryers
Tech-Com failed to initialize the capture device on Vista
I don't know if you have already solved this problem. Here is a solution I came across in one of the sites.
I too had a similar kind of problem... Now, the problem initializing the capture device was solved but still I am unable to view the TV channels.
Nov 24, 2008 | Sabrent TV Tuner / Video Capture Box USB...
The device cannot initialize HDD?
Remove the back panel of the player you will probably find that it will work fine. I did this to my daughters unit and found that the panel was pushed in and depressing the reset button all the time. I rescued it out of the garbage when she bought an i-pod, now I have this unit for myself and it works great.
Jul 26, 2008 | Samsung YH-925 MP3 Player
Pctv hardware initialization failed
first unistall the software. and then remove the hardware device and re insert the slot again. after that install the software. If any other doubt please come to gmail chat at salnazi@gmail.com
Jul 03, 2008 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Pull the battery out, press the trigger for 5 secs and you are done
Apr 25, 2008 | Zebra Symbol Technologies MC909X-G Series...
HP ScanJet 2300C Flatbed Scanner Logo
Seeker5211
Seeker5211
