Whirlpool AWO3561 front load washing machine 7.5kg, keeps stopping and code FP comes up.....
    Brigadier General:
  • 6,277 Answers
Whirlpool 'FP' decodes as 'drain failure'.
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 08, 2011
What does FP mean?
Try looking online for another manual. Or call anyone who sells your machine. Me thinks the solution is simple, but you need to talk to any seller of your machine, and soon.
Mar 04, 2018 | Whirlpool Duet GHW9150P Front Load Washer
Front louding not running . Whirlpool
You need to get inside and clean out pump assembly
Jan 14, 2010 | Whirlpool Washing Machines
My washer keeps stopping 20 minutes b4 the end & displays fp & wont drain
one side of your timer circuit is out! replace timer circuit panel
Jan 13, 2010 | Whirlpool AWM8123 Front Load Washer
My whirlpool washing machine won't spin. In the digital display it is saying FP
Hi
Remove pump and check the pump for any foreign objects which is stopping the impellor from turning.
hope this will help.
Thanks for contacting fixya.com
Oct 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When machine get to rinse cycle it stops and the letters FP appear.
FP means "faulty pump" but before buying a pump make sure to check your drain hoses first since any blockage may cause the same readout in display:
Opene the flap on the front lower right side and unscrew the cap. If it doesn't come out easily a bit of force will get it out - look for hair klips and fluff blocking the pump inlet/outlet hoses.
GOOD LUCK!
Aug 30, 2009 | Whirlpool AWM8143 Front Load Washer
FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Dec 26, 2008 | Whirlpool AWM8143 Front Load Washer
Whirpool washing machine
The FP code just means that your filter is clogged or has a hair doo-dad or something in it that needs to come out. There are Guys on YouTube that will show you how to do that, step by step, just google Whirlpool AWM8103/1 fault codes to see them. Tip* Have a Large but Shallow pan or container of some sort ready to catch the water that the filter will be holding in it's line because it will come rushing out when you open the filter housing! Towels will be useful. Merry Christmas!
Dec 03, 2017 | Whirlpool AWM8103/1 Front Load Washer
Help with whirlpool awm 8103/1
You probably need a new heater element
Nov 25, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
