Question about Kenmore 80412 Microwave Oven
Our Kenmore microwave oven recently stopped heating. The lights, turning plate and controls all work but with no cooking is occurring. The last time I attempted to heat something up I heard a cracking sound as if something had broken, like glass. I immediately shut off the oven and looked inside. Everything looked o.k. I tried again to heat with no success. My model # is 72163252301. Any ideas?
  • Kenmore Master
  • 6,771 Answers
The most likely cause is a bad magnetron, "heats food" the other two possibilities are the high voltage capacitor and diode. The cost to repair will a approach a new microwave oven.
Posted on Apr 08, 2011
My frigidare microwave model #FFMV162LB (about 5 years old) stopped working. I was cooking last night, and in the middle of it, the table stopped turning and the heat stopped. The timer still works and the...
After 5 years of service, there could have been a magnetron failure but the door interlock (latch) could have failed which would acccount for the turntable failure.
Feb 13, 2014 | Frigidaire FFMV162LB Microwave Oven
My microwave GELX1800 is not heating... when the express button is pressed it opens the vent lid and the plate turns around but is not heating. The vent lid should not be open when the cooking buttons are...
Try a hard reset first: Unplug the oven or turn off its breaker for a minute or so, then set the clock & try it again.
If it still fails, did the cooktop lights go out recently?
It may need circuit board repair, which is usually economical.
Oct 27, 2013 | GE XL1800 1100 Watts Microwave Oven
During cooking last night - (about 20 seconds into cooking a piece of fish on a microwave safe plate), it sparked, banged and quit working. Control panel is out. Can this be fixed, or should I purchase a...
I worked for a place that repairs appliances and rule of thumb is if a microwave sparks dont bother trying to fix it just replace it.Microwaves work with so many watts sparks could mean a resister is shot witch could be very dangerous and if it stopped functioning thats probably the case.
Jul 17, 2011 | Whirlpool MH1160XS Convection/Microwave...
Hello, The microwave is not heating up. It turns
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 13, 2011 | Frigidaire FMV156DC Microwave Oven
My JVM1653 stopped cooking, The turntable turns
your magnetron might be out. its what heats
Feb 13, 2010 | GE JVM1653 Microwave Oven
Oven cooks but turntable will not turn, so it cooks unevenly. How do I reset the keypad so it goes back to normal factory presets, in case I entered something that stops the turntable revolving. Is there...
The manufacturer has set the rotational plate in motion at the same time the microwave tube is energized. They work together as a team. At no time should the plate be idol, unless you remove it completely, and then only the center spindle will turn by itself. It is possible for the rotational spindle in the center of the oven to break, but that is unusual unless some sort of pressure (like stopping it when it was moving) was applied. Also, it has been reported that some individuals tend to put items with too much weight or too large for the oven to manage; thus damaging the rotator. As long as the oven still provides Microwaves to cook your food, it is still OK. Years ago, there were no rotating plates and using the energy was all it took to get the job done. For even cooking, just manually stop the oven at times and turn the food to avoid over heating in one spot.
Jan 14, 2018 | Kenmore 62222 / 62229 1100 Watts Microwave...
Kenmore microwave stopped heating
simply stated.. if it fails to cook.. you may have either a bad magnetron tube ( that's the part that generates the microwave energy that cooks the food) or the filament transformer feeding that magnetron is bad. In either case.. you're probably better off replacing the entire appliance than repairing it.. Hope that helps...
Aug 30, 2008 | Kenmore Microwave Ovens
Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
Dec 07, 2007 | Kenmore 62642 / 62644 / 62649 Microwave...
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Kenmore 80412 Microwave Oven Logo
327 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
