Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Bosch #SHE44C dishwasher does not fill. No power to the water solenoid, but power coming out of the control board and the emergency shut off float and switch is working. I need a manual with a wiring schematic and cycle sequence so I don't have to tear it completely apart to trace every wire. Thanks
BIKER T
  • 909 Answers
SOURCE: Power fine, but no water filling the tub
difficult not seeing the valve firsthand but if you could connect a tester to the solonoid and confirm that there is power on the terminals, then you know there is an issue with the valve. typically, if you have a leak, it to will raise the float and shut off the valve.
Posted on Oct 08, 2007
  • 1462 Answers
SOURCE: My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Posted on Nov 26, 2008
  • 86 Answers
SOURCE: where is the float on bosch silver edition?
Hi, This model could well have two systems that will let it fill. One will be on the left hand side as you look at the dishwasher which will require you to remove the side panel. Start with this first as if it is the later version then it will be in the bottom of the dishwasher which will require you to remove the side panels to get to it. The switch in the first method will be a small micro swith and the other will be a large pressure switch located in the bottom. I would think it will be the first method.
Look at it and let me know how you get on.
Posted on Feb 27, 2009
  • 218 Answers
SOURCE: Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Posted on Jul 03, 2009
BIKER T
  • 909 Answers
SOURCE: Bosch Dishwasher with very little water pressure or power
It all stems back to your incomming water supply. Either the sieve is dirt or the valve is blocked with sedementation. Some valves are servicable and some are not,if your valve has screws then its revicable. (low water pressure restricts movement on arms.)
Posted on Sep 18, 2009
On start DW drains but does not fill...putting hot water into machine will get it to start and run cycle sometimes only...
Main control board is bad. Drain sequence is a power on test, Main board is not sending signal to open valve or is sensing water is present in the machine when it is not.
Feb 03, 2016 | Thermador DWHD651GFP Dishwasher
Bosch SHX46AO60C/30 won't fill with water. Have check water under sink - it is on. Motor will run, but no water. Have tried all cycles.
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 29, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
Dishwasher will not fill with water when turned on
Hi and welcome to FixYa, I am Kelly
The following steps require using electrical power. You assume all responsibility / risk for any mis-fortunes cause by working on this dishwasher with power applied.
The first step will require using a meter on the water valve solenoid teminals.
- Remove all power.
- Remove the lower toe / kick panel(s).
- Locate the main water supply line and follow that to the inlet water valve.
- Slide the connector(s) off of the solenoid and read resistance on meter scale R x 1 or R x 10. You should read a low resistance. If you do not read any resistance the inlet water valve has failed.
If you do read resistance you must check switch the meter to AC voltage and apply power and read for AC voltage on the teminals of the wire harness.
- Start a reular wash cycle to where the unit should be filing with water.
it SHOULD read 120 VAC.
If you have no power at the connector teminals
- Check the float switch plastic FLOAT. If the float is stuck in the UP position due to food particulate on the FLOAT stem you willnot have power to the inlet water valve solenoid.
If you have power to inlet water valve solenoid and it is buzzing / humming but you get no water there is debris in the main water supply line. You wil have to shut off the water supply and clean out the inlet of the water valve.
The inlet water valve replaement part is here:
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=233229
Detailed View
http://www.appliancepartspros.com/Appliance-Parts/bosch-water-inlet-valve-assembly-item-number-ap3783031.aspx
This is what the float looks like:
http://www.appliancepartspros.com/Appliance-Parts/bosch-float-item-number-ap2802399.aspx
This is the level switch assembly:
http://www.appliancepartspros.com/Appliance-Parts/bosch-level-switch-assembly-item-number-ap2802390.aspx
This is the actual Float switch: (3 terminal)
http://www.appliancepartspros.com/Appliance-Parts/bosch-float-switch--3-terminal--item-number-ap2802373.aspx POWER to the inlet water valve solenoid comes from this switch.
Check for s stuck float... and that the level switch is actuated as the float id lifed gently up and down. If you do not hear a micro-switch click the switch is bad. If the float is hard to move... clean it as best you can so that it moves freely up and down.
One of the above is causing your problem.
Thanks for choosing FixYa,
Kelly
Jul 27, 2011 | Bosch SHU9915UC Dishwasher
Bosch dishwasher does not fill with water
Hi
Daniel
Jul 19, 2011 | Bosch Dishwashers
I have a Bosch SHE4AM15UC Dishwasher that short cycles. After about 2 minutes it quits and the clean light comes on. The unit doesn't fill with water and the soap dispenser does not open when this...
they will send out an engineer not supply you the part while still under warranty if you fit parts under warranty you will in validate it get the engineer out.
Mar 03, 2017 | Bosch SHX65P05UC Dishwasher
Bosch smu4096ud /14 dishwasher wont fill with water
Find out where the water is being stopped. Firstly at the wall. Then maybe at the solenoid (depending on the model) and then just trace the water line until you find out where it's being stopped.
Also I would recommend you run some nickel safe ice machine cleaner through the system to get rid of the 'white junk'.
Mar 11, 2010 | Dishwashers
Bosch Dishwasher continuous fill/drain
Have same problem with 2 second cycling. I resolder at the point of heater relay. Thought I had solved the problem of running forever on 1. Now have this "new" problem that you have described.
Nov 11, 2009 | Bosch SHU5315UC Dishwasher
Bosch SHU43C Dishwasher
Is there no water coming in( hear no water at all) or no water NOT staying in ( drain motor running) ... the float switch is a safety to keep the dishwasher from flooding ...turns on the drain motor as soon as the door is closed..
I could check the control and see if you have power to the water valve.. maybe a control problem if no power..
Sep 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch water fill
That part sounds like a solenoid valve which opens to let the water in when it recieves electric power. It behaves like a magnet, so put a metal screwdriver on the solenoid area and it will feel like a magnet, therefore it is in the open position. If this is ok but still no water the float switch may have lifted due to an internal leak, check if there if water in the base of the unit.
Aug 09, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
197 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
