Question about Siemens Gigaset 8800 Cordless Expansion Handset
Handset overheating Phone is hot when we pick it up where the batteries are
The display screen is showing the word "SEARCHING" on the screen, can't get the phone to work, cannot pick up an incoming call, the display also displays "HANDSET OUT OF RANGE" WHEN ANY BUTTON IS...
From the Uniden support site.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
reference
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
My panasonic cordless phone goes blank when picked up
Sounds like the batteries in the handset have failed, they will display in the charger from mains power
Jul 13, 2012 | Lands Phones
The DECT telephone is linked to our mainline phone - however it does not pick up the dialling tone or the ring tone. The battery is okay, the signal is good, but you cannot speak on the phone. ...
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 09, 2011 | Uniden DECT 6.0 Cordless Telephone...
Phillips CD445 cordless phone - cuts out when pick up to answer
if you have had it a while chances r the batterys have had it even though they show full, try a new set, or even try standard batterys briefly while fone is not in charging mode to see if they work during a call.
Jul 30, 2017 | Philips CD4450 1-Line Cordless Expansion...
How do you know when your batteries need replaced on Panasonic TG2344?
1. call length is diminished
2. battery takes a long time to - or never fully - charges
3. Handset will not turn on.
4. Handset gets hot during use.
5. Approximately 2 years of regular service.
Any of these indicate it is time to replace it.
Thanks for using Fixya - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 04, 2009 | Panasonic KXTG2344 Cordless Phone
Replaced battery in handset. Got a dial tone and all was well. Picked up handset later in the day and it was dead. Unplugged and reattached everything - no luck.
Try taking batteries out, but also unplug base station. The aim is to disperse all power in the phone so that it resets itself. I would leave everything unplugged for 24 hours and then reassemble and see if the problem has gone. Its worked for me loads of times with different electrical appliances. Hope that helps.
Apr 23, 2009 | Sony SPP A1050 Cordless Phone
Searching In The Display Window
I unplugged the base unit and took a battery out of the handset. I then put the battery back in the handset and replugged the base unit. This corrected the problem.
Jan 03, 2009 | Vtech EV2653 Cordless Phone (73507800685)
Uniden phone
That sounds like the battery is not charging properly. When in the charger there is enough voltage passing to power the handset, but when pulled off the charger it must rely on just the battery. I suspect you replaced your battery because you were having a problem, right? Your problem may be dirty charging contacts. Try taking a pencil eraser to your charging contacts on your handset and base. Try charging your handset again, and ensure your charge light comes on when doing so. Let it charge overnight. Hope that helps. CG
May 26, 2008 | Uniden Cordless Phone
Siemens Gigaset 8800 Cordless Expansion Handset Logo
96 people viewed this question
Top Siemens Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
