Question about Jensen RF10DC 10 CD changer
CD GOT STUCK IN A CDCHANGER IN MY CAR
I WAS TRYING TO INSERT CDS IN MY CAR AND IT GOT STUCK
How can I eject stuck CDs from CD player 2006 toyota camry grande?
Isn't there a security code needed to reset the stereo after a battery change? The Stereo thinks it has been stolen. See your Manual and see your nearest Toyota dealer. Or use a tweezers to reach in and pull out the stuck CD. And clean the rollers with alcohol.
Dec 29, 2014 | 2006 Toyota Camry
How can I eject stuck 3 CDs from CD player + GPS 2006 toyota camry grande?
there is small pinhole on the front of the player, you need to push thin stiff wire (paper clip straightened up will do) and this will mechanically release lock on the players doors, retract the doors fully and remove the dvd's.
I am trying to connect alpine cd changer to 1999 isuzu factory stereo.
It willnot work, You have to have the same brand of changer as your (Deck) Allso the deck has to be equiped that you can hook up a changer to it,
Oct 24, 2012 | Pie ISU/98-ECL 98-01 Honda/Isuzu/Acura...
I bought a 03 ford explore eddi bower . its 6 disk changer had cds stuck init got two of them out and the door shut but wont except any cds said cd error/cd full.but i dont think there are any left in...
Honestly I wouldn't even bother going through the trouble and hassle of trying to "tinker" on the system to make it live again. Once these suffer a malfunction like this they're for the most part dead.
Jul 09, 2011 | Car Audio & Video
After jumping a dead battery (hot shot) the CD player died. It gave an error: it thinks that there are no cds inserted when in fact there are 5. It will not eject and I cannot insert. My hope is that I...
After my car battery went dead my cd player is stuck. It won't play, or eject and it thinks there are no cds in it when in fact it is full. HELP!
Oct 31, 2010 | Car Audio & Video
Cds are stuck in the default cd player of 2001 Dodge Intrepid. How do I get them out?
The first step is turning the car off. Then before turning the key back on, push and hold the Eject button then turn the ignition on. If the CD fails to eject then you can use a old CD and try to insert it into the CD Player, just as it try's to take your second CD pull it out and hit the Eject button again. This will usually get a Dodge CD player to Eject.
If this fails then the CD player must be removed and a manual eject can be performed.
May 15, 2010 | 2001 Dodge Intrepid
I have a 1996 ford explorer and the 6 disc cd changer is stuck and will not eject, I can hear it trying when I press eject button, any ideas???
good day. well if some kinda stuck you should open it manually. you can find a little hole on the cd changer just use a paperclip then insert it to the hole it will be open manually. and hope that it will not trip right after you put the cds again. hope this helps
Feb 04, 2010 | Car Audio & Video
07 honda odyssey EX-L CD won't play
I have an 07 honda odyssey EX-L with a 6 disc CD2_bing.gifchanger. It currently has 4 CD's inside. None of them will play. Theradion and DVD work fine but I cannot even choose to play the CDs. They will not load nor eject.
Jul 27, 2009 | Car Audio & Video
Xtype 2002 CDChanger
Be careful make sureonly usng genuine cds hace seen copies with same problem, or the laser itself could be faulty inside stacker
Mar 12, 2009 | 2002 Jaguar X-Type
HU 850 CD stuck in player
One thing about Volvo CD player/changers...they tend to not like burned CDs and even more, burned CDs with labels on them.
I'd suggest against trying to get it out yourself.
You can get it replaced and the dealership should have a form so you can get your CDs sent back.
Aug 02, 2008 | 2005 Volvo S60
Jensen RF10DC 10 CD changer Logo
70 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
