Question about LG Washing Machines
What is the problem if the LG Fuzzy WF-T1330TP top loader shows error code PE.
    Guru:
  • 500 Answers
Pressure Switch faulty.
Replace with P/N: 6501EN1001A
Reply if you need directions for removal & installation.
Good Luck!
* If you found this solution helpfull, please rate with 4 thumbs up & a testimonial.
Posted on Apr 08, 2011
Lg turbodrum fuzzy logic 7.0 wf t700 showing error code "de" what that is mean? And how to fix it?
Try unplugging power, push and hold power button for 5 seconds, then plug back in. See if error code is gone.
Nov 05, 2017 | LG Washing Machines
Hi I have a lg fuzzy logic wf-1022tp top loader. When I switch it on it says PE pings whole time please HELP
PRESSURE SENSOR ERROR // Water level pressure switch error
The manufacturer has assigned this error or fault code to indicate that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Jul 04, 2016 | LG Washing Machines
Fault PE....How do I replace the pressure sensor on an LG fuzzy logic 5kg wf-t502 top loader and where can I purchase this part?
PE Means pressure sensor error this spares is very rare to defect 1st check full pressure sensor the wiring harness any damage or wire cut means the error will show in display
Mar 26, 2015 | LG Washing Machines
Hi ihave a lg fuzzy logic wf-1022tp top loader. When I switch it on it says PE pings whole time please HELP
You have a problem with the pressure switch (water level sensor).
Either a faulty switch, blocked air chamber or hole in the pressure hose linking the chamber to the switch.
Thanks
Jul 14, 2014 | Washing Machines
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
Washing Machines Logo
424 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
