Question about HP Designjet 110plus InkJet Printer
My plotter have four ink cartrrrige the cartrridge is full but he (B C M Y) dorsn't showing black ink so what can i do i am swap another new cartrrige and he is show a ink is blank so kindly inform that what i do my name :- MANISH PURBIA
rakeshpramod
  • 234 Answers
SOURCE: Black cartridge problem
Try the steps mentioned in the link bellow:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01091133&cc=us&lc=en&dlc=en&product=1141647
If it still does the same then the printer is not detecting the ink catridge, the printer might have to be replaced.
Good Luck
Posted on Sep 01, 2008
  • 39 Answers
SOURCE: problem with new ink cartridge
More that likely the refilled ink cartridges are faulty and should be replaced. While some folks have pretty good luck with refilled cartridges, it is generally better to stick with the new ones.
As to the problem with old cartridges, keep in mind that the estimated ink levels are just that - estimates. However, if your printer has an option for cleaning the cartridges, try that before chunking them. Take them out, put them back in, and run the cleaning process. Sometimes the nozzles can get clogged up and running the cleaning process will clear them up. ( DO NOT TRY TO CLEAN THE CARTRIDGES MANUALLY!)
If none of this helps, you will more than likely just need to get some new cartridges. - Graye
Posted on Nov 24, 2008
  • 298 Answers
SOURCE: HP C6280 says out of black ink
Something is wrong with your Blach carrier or connections. Use a bit of alcohol and clean the array of gold contacts where the Ink cartridge plugs in. Most of the pins are shutter and piezo control (get the ink on paper) but a few do other stuff like check ink level, # of hours runtime, etc. This is very common problem with inkjet printers. Hope this helps.
Also... rub the contacts on the printhead with a pencil eraser to make them shiny and bright.
Cheers!
Posted on Mar 26, 2009
  • 672 Answers
SOURCE: just installed refilled color and black ink
I found these instruction at out-of-warranty.com They seem like a possible solution.
Steps:
  1. Press Cancel and Power, at the same time.
  2. Then, the Unit will ask for a Key Combo, press blue, green, gray buttons (in order) for this.
  3. “Support Menu” should appear.
  4. Go to Resets menu and use the semi-full reset.
I hope this is helpful. Good luck.
Posted on Sep 05, 2009
  • 5 Answers
SOURCE: installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Posted on Jan 22, 2010
HP DesignJet 500 - Printer will not recognize any of the four ink cartridges
>Your have new cartridges,not refilled right?
>Remove cartridges,
>Remove right door,
>Check ISS unit cables,PCB & connectors as shown in snap shot,
Most of the cases ISS arrested with ink leakage from cartridges, result connectors,PCB tracks & cables got damaged.. check perfectly if found shoot the problem....
> Replace ISS unit,, But only professionals can do the replacement..
*** Reading, writing & initializing the backup EEROM located in ISS unit, if any thing goes wrong both ISS & Formatter assm both will loose their memory..be careful..
Dec 05, 2011 | HP DesignJet 500 InkJet Printer
My printer keeps flashing check print cartridge, Both black and color are flashing. I have Just bought a new 92 Black cartridge and the color cartridge is full ... why is this happening?
While reseating a cartridge is not difficult but there are a number of errors that can occur if the user does not manage it properly. Reseating a cartridge should not be a difficult task for anyone with a passing knowledge of printers. The reseating error can occur after the user has replaced the black ink cartridge. It is a common problem with the black ink cartridge. The user may attempt to replace the cartridge number of times, clean the contacts and restart the plotter. If there is a problem with replacing the black ink cartridge that cleaning the contact does not fix, then it is best to simply replace the carriage assembly first. If this does not solve the problem then the user may want to consider replacing the trailing cable.
Nov 17, 2010 | HP Office Equipment & Supplies
I have a message showing bk tank - code
Its detecting an incorrect ink tank.
The printer is not happy with one of your tanks. Make sure you have PB inks if it is a PG printer.
More probably the job you are printing requires the other black ink tank. Very important to make sure your status monitor is installed correctly, make sure when you send a job that it displays the ink tank levels and not question marks. You should be able to find out roughly how much ink is left through the driver (status monitor) and also what type of black is installed. If you cant, you have not got the 'Status Monitor' installed.
Mar 09, 2010 | Canon imagePROGRAF W6400 InkJet Printer
Cyan ink discharge at the back of the ink crtrige.
The leak is from the cyan ink cartridge or from the connections in the ink tube system. Replace the ink cartridge first. If that does not fix the problem, replace the ink tube system.
Jan 13, 2010 | HP DesignJet 1050c InkJet Printer
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
HP Designjet 500ps 24" Plotter- screen says to replace printheads
Printheads are available everywhere, you replace them your self. Machine will usually indicate just one bad print head at a time.
Dec 22, 2008 | HP DesignJet 500ps InkJet Printer
Error message E02530 on canon plotter w6400
Go to the Utility page in the printing preferences and click the button to "Update Ink Information" make sure the black ink type matches the one in your plotter.
Apr 14, 2008 | Office Equipment & Supplies
Ink problem
First, are you using a genuine cartridge? If not, Brother is very finicky. Get one. Second, uninstall the print driver and reinstall with the latest from the Brother site.
Dec 05, 2007 | Brother MultiFunction Center MFC-440CN...
Ip4200 stopped printing...help!
dear oceantracks maybe one of the black cartridge chip think that ink is running low or not ink is left in the cartrridge.
Nov 21, 2006 | Canon PIXMA iP4200 InkJet Photo Printer
HP Designjet 110plus InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
