Question about Brother MFC-8220 Fax
MACHINE WILL RECEIVE BUT NOT FAX
I am getting an A6 error message when I go to fax and the paper will not advance into the machine.
  • nene684 Jan 05, 2009
    can recieve fax but not send them out brothers fax machine mfc 8220
    Genius:
  • 2,120 Answers
That code is a Bad Main Board.
Try unplugging power cord for 10 seconds.
Posted on Oct 11, 2008
Error Code R.3.1
YOUR PROBLEM IS CAUSED BY STATIC ON THE PHONELINE NOT YOUR FAX. BOTH MACHINES TRY TO SLOW DOWN TO UNDERSTAND INTERNATIONALMESSAGE OF FAX COMMUNICATION THEY MUST UNDERSTAND 95% OF MESSAGE OR THEY WILL DISCONNECT YOU CAN TRY NEW PHONECORD 1.00 AT DOLLAR STORE ORCALL YOUR PHONE CO.
Apr 09, 2010 | Muratec F65 Plain Paper Thermal transfer...
Fax reception fails
Hello Dear,
The error message 242 appears in HP Photomart C7180, when the remote machine (the fax machine at Fax Sender side), is having problem, and it is trying to receive fax instead of sending. So actually both these machines try to receive the fax at the same time.
On many fax machines it is possible to accediently initiate the fax reception when:
1. The paper is not loaded in the machine
2. Or The paper is not correctly loaded.
You may contact the fax sender to check the above things. There is absolutely no problem with machine at your end.
Thanks
Mar 10, 2010 | HP Photosmart C7180 All-In-One InkJet...
The fax paper can not go through, and the window turn red light said error A6
You will need to take it in for service.
Machine Error A6 is an indication of a mechanical malfunction and the unit will require servicing.
See this link on the Brother website:
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000005512&Sympt=Why+does+my+machine+display+the+message+Machine+Error+A6%3f+MEA6&Model=101&ProductGroup=5&Keyword=A6%20error&ProductID=MFC8220
Aug 10, 2009 | Brother MFC-8220 Fax
Brother Fax-1030 plain paper sending constant 'check paper' error
I got this error when I put the paper in without pulling forward the flap that hold the paper. It seems that the action of returning the flap to it's closed position sets the paper in the correct way.
I'd give that a try.
Mar 16, 2009 | Brother FAX-1030e Plain Paper Thermal...
Receiving Problem
Do you have a DSL or any other digital phone line?
Are you set to "AUTO RECEIVE" ?
Call the fax machine from a regular phone and listen for fax tones.
Sep 29, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Will not receive Faxes
The first thing you can try is replacing the phone line between the wall and the fax machine.
Sep 15, 2008 | Sharp UX 510 Plain Paper Thermal transfer...
FAX MEMORY FULL
Please feed paper in fax machine and get prints of all messages. this will free machine memory. 2nd option is to reset the fax machine, if this option is available in your fax.
Aug 20, 2008 | Office Equipment & Supplies
Fax Canon JX200
is there any error messages coming out from your fax machine.see the error messages first.the paper should run smoothly during sending and receiving process
May 06, 2008 | Canon FAX-JX200
Error message on Canon Fax Machine 2050P check cover/cart
there are a couple of things did you buy genuine or reman cartridges and check if they are seated properly.
some remans dont work properly so you have to be sure and always get a money back guarantee from the seller
Feb 26, 2008 | Canon FAX-L350 Plain Paper Laser
Error Message: Scan Unable A6
did you get the solution to the problem u mentioned
Feb 21, 2008 | Brother MFC-8220 Fax
Brother MFC-8220 Fax Logo
709 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
