Question about Otterhouse Otterbox Nok4-N97Xx-20-C5Otr Nokia® N97 CommuterTM Case - Cellular Accessories
N97 charging problem - Otterhouse Otterbox Nok4-N97Xx-20-C5Otr Nokia® N97 CommuterTM Case - Cellular Accessories
Nokia n97 charging solution
Hi If the USB Socket (usb board) found no damage the only thing is to apply jumper.So, you can contact nearest mobile repairing shop or follow this link N97 charging solution.Thanks for visiting fixya
Aug 20, 2012 | Nokia N97 Cell Phone
My nokia n97 is not charging its show not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 14, 2012 | Nokia N97 Cell Phone
CANNOT CHARGING MY NOKIA N97, THE INDICATOR LIGHT IS NOT BLINKING, ONLY DISPLAY NOKIA AND THEN OFF
Please check your battery, it might have already been damaged. My battery was already bloated, and hard to put the back cover when I encountered the same problem. You may also borrow a battery, from a friend just to verify it. Before checking the battery, I did some verification using a known good nokia charger from a friend, and still could not charge it.
P.S. I replaced my battery after using my N97 for more than 3 years.
Feb 05, 2011 | Nokia N97 Cell Phone
Hi, I am facing problem in getting my new Nokia N97 recharged. When i turned my Mobile Off the charging light on left side appears very bright and Mobile gets charged properly. but when i turn it on and...
this issue is generated from some types of software problems, you need to get back to Nokia dealer and they will solve you the problem in a seconds
Aug 25, 2010 | Nokia N97 Cell Phone
Hi my new n97 wont charge or turn on
I bought a brand new nokia phone N97 but it does not charge. What must I do?
May 31, 2010 | Nokia N97 Cell Phone
My nokia N97 just doesnt charge please HELP!
The problem is very clear, since you said you no matter the charger you use.
The problem with your phone is the charging port, the charging port of your phone is bad and will need to be replaced.
Replace the charging port and your phone will charge.
Take care.
Apr 20, 2010 | Cell Phones
Hi,my nokia n95 wont hold charge i have a new battery and new software,do you know what the problem could be,also when it charges it doenst cut out when it is charging it just keeps charging,thank you
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dear user,
Such issue may appear when Nokia charger adapter CA-146C is used with incompatible charger to charge Nokia N97. Currently compatible chargers for N97 with CA-146C are Nokia Travel Charger AC-4 and Nokia Compact Travel Charger AC-5.
Spangley, just plug it into your PC. If your battery needs charging, it will charge slowly simply while being connected to your computer. Nothing else to do!
Goodluck :)
Dec 11, 2009 | Nokia N95 Cellular Phone
Otterhouse Otterbox Nok4-N97Xx-20-C5Otr Nokia® N97 CommuterTM Case - Cellular Accessories Logo
256 people viewed this question
Top Otterhouse Cell Phones Experts
Computer Repairing
Computer Repairing
John mullen
Katlin Donnelly
Are you an Otterhouse Cell Phone Expert? Answer questions, earn points and help others
