Question about Epson Office Equipment & Supplies
Doesn't print. Printer offline - Epson Office Equipment & Supplies
    Scholar:
  • 85 Answers
Check if the cables are connected, and the printer is powered on. There are usually 2 cables, 1 is connected to the computer's usb port, the other is for power. Make sure both are connected and inserted firmly into their respected ports. If all are connected, check if the printer driver is installed properly. Look for your printer in Start -> Settings -> Control Panel -> Printers and Faxes (if you are using windows xp). If you can see your printer there, there is a chance that you have a defective printer which needs servicing.
Posted on Apr 08, 2011
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Wireless printing doesn't work
Is the printer set as default in the printers? I need more info to give a solution. Is the printer offline? Try to delete the printer and re-add in software. What message do you get when you try to print to printer? Are your documents in Que to be printed? If so Delete /cancel and try to print again.
Nov 02, 2012 | Acer Aspire One PC Notebook
Problem with Brother MFC-9840CWD
Hi,Check to see in the connectioncables are all plugged in correctly.Open the printer and see if drumunit and toner cartridges are installed correctly. Sometimes not well installedconsumables are the cause of that particular problem.See if the print driver on yourcomputer is correctly installed. Try and reinstall the driver.Check if your printer is working in onlinemode. Sometimes printer changes online to offline method. If printer is atoffline mode click Start button on your computer, enter Control Panel. Click onHardware and Sound and choose Printers. Right click on Brother MFC-9840CWD andmake sure that the Use Printer offline is not checked.Hope this helps.
May 09, 2012 | Brother MFC-9840CDW Laser Printer
My canon i9900 is offline
It usually means that the printer is off, not connected to your computer or your computer does not recognize it. If your computer doesn't recognize your printer, go to control panel and click on add new hardware, then follow the directions . After trying all the above try using your printer once again.
Mar 18, 2012 | Canon i9900 InkJet Photo Printer
Printer is offline and i can't get it online
Ok one printer prints and the other one just stares back at you.
Take the one that prints and pull the network cable from it.
Now try printing to the other one.
I don't think that two devices with the same IP address work.
Nov 15, 2011 | HP LaserJet 2430dtn Printer
HP Deskjet 9800--when i try to print, it doesn't. When I click on the printer icon, it shows that the printer is offline, but it is not.
Disconnect the power cord from back of printer ( printer must be powered on ) and wait for 30 secs. Connect it back.
Try to print. If it still does not print, click on the link below and follow the instructions to resolve your issue.
Clear Print Job Stuck in Queue
Regards,
Ron
* Rate this solution with Thumbs up and comment to help us improve providing support
Jun 12, 2011 | HP DeskJet 9800 InkJet Printer
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
SHARP AL-2040CS offline after reboot
Official Sharp driver had set "use printer offline" setting in the printer properties context menu. After unselecting the "use printer offline", printer is printing again, even after reboot...
Jun 17, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Printer won't print says it's offline
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
Apr 04, 2009 | HP Deskjet F340 All-In-One Printer
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
