Question about Western Digital 2 TB SATA 6 GB/s 7200 RPM 64 MB Cache Bulk/OEM DESKTOP WD2002FAEX (Caviar... Hard Drive
My WD 6bg pocket HDD isnt appearing on my computer but my desktop shows it had detected the WD 6bg HDD and it shows no problem at all... But there is none on my computer...
  • Western Digital Master
  • 27,725 Answers
Click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage your computer
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 08, 2011
WD Elements SE 500 GB/Go not detect in my computer
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery software to recover files.
http://www.asoftech.com/adr/
Aug 31, 2011 | Western Digital Wd Elements Se 1tb...
My wd (my Passport) hard disk is not detecting and open in my computer
How many HDd you have plugged with your computer.????????????????/
Jan 12, 2011 | Computers & Internet
I have a Iomega LPHD120-U, it was working fine but in the middle of a program a msg saying content lost popped up and since then the hadr drive doesnt open up. on connection it the green light appears for...
You might try opening it up and seeing if you can pull the HDD and put it in your PC as an auxiliary drive. If it works, the interface or power supply was bad.
If it's intermittent, get all the data off it ASAP, because you'll probably not going to get much use out of it.
Apr 07, 2017 | Iomega 1TB Desktop USB 2.0 Hard Drive
External HDD not detected
have you try with the other usb cable and the usb port.
Jan 20, 2010 | Western Digital 320GB MyBook External USB...
I have hp d260 cpu, In my bios i have auto detect hdd settings, but it shows no hdd inspite of working hdd attached. when we tries to manualy detect the hdd it shows but as soon as we restart the pc it...
GO BACK TO BIOS AND SET TO LOAD SAFE DEFAUT SETTINGS.YOU SHOULD STAY OUT OF BIOS,ARE YOU A COMPUTER TECH PERSON.IF NOT STAY OUT OF BIOS OR LEARN THE HARD WAY........HOPE THIS HELPS!
Nov 30, 2009 | HP Computers & Internet
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
WD Mybook 320. Detected by computer, files all shown, but cant ac
Download the software Recover My Files , google for it and install the software. U can recover with the instructions in the software. it is very easy. U will get the files..
Sep 16, 2009 | Western Digital Passport WDXML800UE...
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
Western Digital 2 TB SATA 6 GB/s 7200 RPM 64 MB Cache Bulk/OEM DESKTOP WD2002FAEX (Caviar... Hard Drive Logo
71 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
