Question about Whirlpool Duet GHW9150P Front Load Washer
Keep getting a beeping error not allowing machine to finish washing
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 08, 2011
Our miele w911 washing machine keeps stopping in the main wash cycle - red light above the tap symbol. What does it mean?
check that the water flow solenoid is operational and not blocking of the spray rinse requriement
Mar 23, 2015 | Miele Washing Machines
What is the procedure to stop the beeping when wash is done. Not only does it beep it keeps on beeping every 30 sec.?
My one beeped every 30 seconds to tell me that the cycle was finished.It should stop itself after about 15 minutes,or just turn the machine off.
Jun 08, 2014 | Bosch Classixx WFL 2066 Front Load Washer
I am getting an error it is as follows: finished, spin, and wash lights blinking plus 3 beeps. What does this mean?
Try restarting it, make sure the load isnt to heavy, if that does not help, call a local repair man.
Nov 06, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Keeps pausing
What is the model number of your unit?
Feb 03, 2013 | Whirlpool Washing Machines
Door remains locked after wash, no error code or anything.
if there is water left in the machine it will not open pull out the washer if under work top tilt the machine back wards the door should open thwn clean filter and try
Dec 02, 2012 | Washing Machines
I have a Bosch Exxcel washing machine which is great but it bleeps for ever and a day when the wash is finished. How do I silence the beeps without having to get up?
Switch machine on but do not program.
Press and hold PREWASH button.
After a few seconds it begins beeping.
Keep holding PREWASH button in until beep gets quiet
then eventually stops.
Hope this helps - Colin, Billericay Essex
Apr 11, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
My washing machine keeps giving me a error 20 code and dosent finish the cycle
E20 is a general error code to get to the real problem try this..
Reading Error Codes2.gif 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash2.gif. let me know what code come up... hope it helps
Sep 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
My washing machine wont work properly!!!!!
may i suggest that you check that the filter is not blocked, i had a very similar problem to this except my machine stopped washing and started making a beeping noise.hope this helps
Aug 03, 2008 | Washing Machines
Frigidaire Front Load Washer
It looks like the door switch was not making because the door is defective. Also the switch may just be bad.
Mar 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
13 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
