Question about Gestetner DSm615 Digital Imaging System
The paper comes out wrinkled and when i check inside one of the 3 fingers in the pressure\heater unit is broken.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
This problem always happened change paper kind if yo use 60g change to 70g and use good paper
Posted on Apr 08, 2011
Why is my photo copier wrinkling the paper sometimes?
Check the lower pressure roller at the heater unit for damage.Also see to it that the copies are alligned before it enters the heater unit ..
Aug 01, 2014 | Toshiba 6LH58317000-OEM Estudio 355...
Why is my paper coming out wrinkle Dell B1160W
Could be a number of factors.. first humidity affects paper, if there is moisture in your paper...caused by air conditioners constantly running .
check the paper by placing the back of your hand to the paper that is in the paper tray and or the package for a very cool feeling, this will definitely cause the paper to wrinkle when coming out of the fuser unit.
Also it could be charging of the paper during the transfer stage..which can be checked by starting a copy and trying to catch it before the paper enters the fuser rollers ..too late if it comes into contact with the upper and lower pressure rollers of the fuser unit.
Also the fuser unit definitely needs to be checked as a major source of wrinkling of copies..sometime the fuser roller will start loosing some of it's coating which you can easily check by viewing the condition of the upper roller.
Anyway it's either moisture in the paper, charging of the paper, or the fuser unit is the probable suspect.. check them all.
Jul 09, 2014 | HP LaserJet 2840 Printer
Xerox m 24 creasing paperon A3 prints
check the pressure of the fuser adjustment
Oct 23, 2009 | Xerox WorkCentre M-24 Color Copier
Paper is getting jamed as it attempts to enter the finishing unit.
Hello sir; First, check out the paper path have anything stuck inside, otherwise go to replace paper exit senser on the machine or paper entrace senser on the finisher ( depend where got paper jam).
Oct 09, 2009 | Toshiba e-Studio 45 Black and White Copier
After paper jamming in printer paper now wrinkles
there still may be a piece stuck somewhere in the unit. Remove printer cover and check inside to see if there is anything at all still in there
Jul 29, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper gets wrinkled in the paper guide and gets stuck
The "pick-off fingers" are supposed to be contacting the roller. They have tension springs that pull them down. One of yours have come off, or possibly the finger has broken off where the spring connects, so now the paper is running into it rather than crossing over it.
In the interest of saving a service call, and time. You can simply twist it off with a pair of pliers. Be careful not to bend any brackets/housings. It will run fine with 1 removed.
Eventually the fuser rollers will need to be replaced in your machine, and you can have a new finger installed if you want.
Please rate me. :)
Jun 17, 2009 | Sharp AR-207 Copier
PRINTER CRUNCHES AND WRINKLES PAPER WHEN TRYING TO PRINT
ok, in this case you need do:
1) check the roller before the fuser and after it some roller old not enough firction and pressure balance
2) check the fuser press roller it could not has good tough to fuser surface, it should be no gap at all and good pressure balance on the fuser surface
3) check the fuser cleaner which maybe too dirty, or change new one if you have the parts.
4) fuser unit maybe too old if printing pagers over its life cycle
hope this help you and please ask me any time.
May 16, 2009 | HP LaserJet 3030 All-In-One Printer
Paper is getting crinkle up
If the paper if getting a fan fold and then jamming at the fuser unit, this would suggest a pick off finger may have come off its mount or spring. If the paper clears the fuser ok put has an elephant skin type wrinkle down it, then this would suggest fuser is past it's best and should be replaced. Remove the fuser and check there is nothing wrapped round one of the rollers. If all is clear, change the fuser.
Sep 08, 2008 | Samsung CLP-510 Laser Printer
Wrinkled paper
Try checking the fuser unit inside the back of the printer. Open the door and pull the paper path tray down. You should see an orange vinyl looking roller. If is has wrinkles it probably needs replacing. I have replaced two on my printers and that corrected the wrinkling problem. You can get them on ebay.
Oct 24, 2007 | Brother HL-5250dnt Laser Printer
42 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
