Question about Maytag Neptune MAH5500B Front Load Washer
Dont pull the water selenoide good fus gud
    Brigadier General:
  • 6,277 Answers
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Good luck,
John C
Posted on Apr 08, 2011
Wiring diagram wiper motor for bmw 316i
sounds like the wiper control switch is at fault
Mar 05, 2014 | Cars & Trucks
Water leaking out of soap dispenser?
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Mar 17, 2013 | Washing Machines
GE ETERNA not making ice or water
i had the same fridge i had to replace line in the back i dont know how but busted and when i try to get water in front door will end up in floor, also it has a selenoid that could not be working.
thanks, and good lock
Mar 03, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
2 problems
Sounds like the selenoid valves are backwards. Or the water hooked up backwards. Or actually like the cold water one isnt working at all. Either the selenoid or the screen stopped up. Even on cold water i noticed that some washers use warm. But all of them uses cold water to rinse. At least the last rinse. So when it uses cold water there isnt any. First of all, Switch the two wires with each other and wash on hot and see if cold works then. If not Take the selenoid out and apart then clean the diaphram real good with soap and water then pup back together.
May 31, 2010 | Maytag MTW5600TQ Top Load Washer
My kenmore refrigerator 106.56166500 quit dispensing water. Icemaker works fine. I disconnected the water line at the bottom of the front door via the quick disconnect and I get water from the supply side...
The line inside the freezer door is frozen . Turn the temp in the freezer , to warmer for a few days , and it should thaw . A dispensor heater is available , pt # WR49X10173 . Instructions come with the part .
Nov 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Overheating...changed radiator, pump, and im not sure all what else...a friends car..i dont know if its a head gasket or a solinoid...any suggestions. its a 97 328 ic i believe.
Leave the pressure cap off.Run engine and check if you having any air bubbles in the water.If yes a blown head gasket.If no replace the thermostat.Make sure the fan is in good working order.
May 31, 2009 | 1997 BMW 328
Aube CT280-2H1C exit pin for humidifiers dont give 24vac
My carrier humidifier does not show any runoff of water in the over flow. it does not appear to be getting water
Jan 28, 2009 | Humidifiers
Water supply to selenoid is OK, but no water from selenoid to uni
Try to clear the small pinhole in the fitting leading into the selenoid. Sometimes this gets blocked with dirt or sand.
Dec 02, 2008 | Honeywell HE360A1027 Whole House...
My water dispenser is not working.
Nope, its imposible to frees that line ,however there are two selenoides in the water in take located in the back of the frigi check if you heard a click sound wen you activate the water switch if not then you have to change the selenoide if yes look for water obstrucion in the water server...good luck and rate me
PS somes time they click but are cloged
Jan 22, 2008 | GE GSH25JFR Side by Side Refrigerator
Maytag Neptune MAH5500B Front Load Washer Logo
57 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
