Question about Samsung DCS 12 Corded Phone
Night Bell/Ring Hi, I have yet another question. I have a iDCS601 and am wanting to know when I put it on night ring at the end of the day, is it possible to set up the phone so that you can hear it over the intercom so everyone can hear it? We don't want it to ring to every phone, just over the intercom. thank you, Lauri
  • lthomas790 Aug 07, 2008
    That would be great to get your recomendation for a tech, we are in the Tualatin, Oregon area.
    Thanks! :o)
    Lauri
    Scholar:
  • 108 Answers
Hi Lauri, when the incoming caller rings your number the ringing sound you hear is from the intercom ( Call 1 ) button on the phones programmed to ring. If you only want a few phones to ring, like the Station Group programmed in MMC 601 it will require accessing several different MMC's and you can really mess up your ringing assignments and not get any calls at all. I know you do not want to hear this but do you have a Vendor that takes care of your system? This is a problem/request that an experienced Sansumg Tech should tackle. Let me know your city and I can find you a local Tech. .....Mike
Posted on Aug 07, 2008
  • Michael Bowen Aug 07, 2008
    Hi Lauri, I called Valley Tel Services in Milwaukie which is about 8.7 miles from your zip code and they have iDCS 500's installed so there should be no problem with the programming and they are an authorized Samsung dealer. The contact number is (503) 353-1644. There are six dealers in your area so if you want the list I'll be glad to give it to you. Let me know and Good Luck. Thanks for the FixYa rating. ....Mike
When I put my t7316E on "night" it only rings half ring then sends call to answer machine, Any way to change to a few rings so I can answer it if needed
That is generally how Night mode works - alerting you to a call then directing the caller to voicmail night message. You want to change the Forward No Answer setting in that mode; if your system doesn't support that, set FNA in regular (non-Night) for the attendant phone.
Oct 09, 2014 | Nortel T7316E 2-Line Corded Phone
When in night mode, how do I make the samsung idcs 18d ring on every extension
if you know your password for your phone system do this. enter programming mode by pressing transfer key, type 800 enter your password then volume up key then speaker key. go to program 601 station groups find unused station group ie 510. make this group unconditional and under members add all thr extensions you want to ring then press speaker key. then go to program 406. enter line number of line and under night mode tell it the station group number you programmed above
May 07, 2014 | Samsung Falcon iDCS 18D Display Phone with...
Night owl optics night vision monocular model # nocx5 explorer pro . thin wire inside battery compartment has been severed. anyone know where i can get this repaired? unit worked fine b4 this happened....
Yes, at Night Owl Optics in El Paso, Texas. This is not a mandatory option. You can do it you self. You can see the white wire in a slot just under the aluminum thread ring for the battery cap.
Is this where the wire is broken at?
Need a small dental pick with 90 degree bend on the end/you can make one, also some tweezers or small needle nose pliers. Use the hook to remove the aluminum ring that is press into the plastic case.
Once, the ring is removed, reach in the Small slot with the tweezers and grab the wire. Now, gentle and I mean gently pull on that white wire until you enough wire to strip the teflon coating off.
Now, use the pick to cut a little small **** in side where the battery cap ring goes. Now, put a very minute drip of glue in the wire ****. Push the wire into the glue **** with the pick. Now, you can install the aluminum battery cap ring. Gently push it down and let the glue dry. Your done...awesome, no.
GB...stewbison
walk gently upon this earth, and she will good to you.... NO means Yes here!
Sep 05, 2011 | Night Owl Optics Explorer Pro NOCX5...
I can ring out on phone but the phone or base wont ring on incoming calls night mode is not on and all the volumes are turned up
It sounds like you don't have it programmed to ring. The volume controls the sound, but programming controls the ringing. Try night mode (782 from extension 101) to put it into night and test again, or check out the sytsem programming for ring modes.
Carl
May 06, 2010 | Panasonic KX-T7730 Corded Phone
Enabling a extension to ring on night mode
We may need to know the exact system you are using and the model of phone.
Also we will need to know the group number the system is using for night mode. Normally group number 601 is day and 602 is night. If you call 602 that would ring the phones currently in night. Also you can try calling at night and watch the screen of the phone that rings if its a smaller screen phone press the info button while its ringing and one of the options will show the night ring group number as well.
Respond to this and I can further help.
Jul 22, 2009 | Panasonic KX-T7630 Corded Phone
Selecting a custom recording.
I was told that the day and night settings in the local applications must be the same. It is in your night call routing table that you need to place the extension in order for the system to know which recording to play when. Then, your system will play the application when it is set in night mode. Hint: When you place the extension in the call routing tables make sure the extension is placed ABOVE the +ALL CALLS line, if applicable, and your ring-in-destination is set to your appropriate application recording. I hope this helps.
j
Dec 15, 2008 | Inter-Tel Axxess Corded Phone
Night switching for KX-T7630
You have 4 different modes of calling available to be programmed: DAY NIGHT BREAK and LUNCH. Your installer has to set up the ICD groups, but you can create a LUNCH group which looks like the day mode but rings all phones. The codes are accessed by dialing on the intercom *780x where 0 is day 1 is night 2 is lunch and 3 is break.
You may use the NIGHT mode in the daytime, but if you have voice mail, it will play the night greeting instead of a day greeting.
Carl
Sep 09, 2008 | Panasonic KX-T7630 Corded Phone
Night button and incoming calls
The programs involved with you ringing are 81 ( no light or Day Mode ), 84 ( blinking red light or Day 2 Mode ), and 87 ( solid red light or Night Mode ). To change the ringing assignments you need to know the port numbers of the phones you want to ring or not ring. You can do this by pressing DN/ICM dialing # 4 0 2 at each phone, the diaplay will show the physical and logical port numbers. These numbers will be used to turn on or off the aaociated lamps within the above programs. Do you have anyone on staff that understands the system programming ? Let me know ...Mike
Jul 17, 2008 | Toshiba DKT-2020 Corded Phone
Night ring
The manual day/night switch can be made from the operator ext (usually 101). This will over-ride the preset schedule.
Press:
[SHFT], [FEAT], scroll jog dial until you see Night Mode, [SEL], then press [0] for night or [1] for day.
To change the automatic start and stop time is, indeed, a phone guy (or gal) function.
Page 4-33 in the System programming manual.
Dec 09, 2007 | Panasonic KX-T7453 Corded Phone
Samsung DCS 12 Corded Phone Logo
251 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
