Question about SmartDisk 160GB FIRELITE PORTABLE FIREWIRE HARD DRIVE 5400 RPM 2.5IN 160 GB FireWire 400
My new netbook will not recognize the drive. I have plugged it into all three USB ports and it will not read it. Almost every time with out fail, I hear the alert that notifies me that the device was plugged in, but it still does not read. It reads perfectly on an older desktop computer running Windows XP as well as my son's laptop which runs Vista. I have used different USB cables other than the one supplied with the device (in attempting to troubleshoot) but to no avail. Please advise.
  • 22 Answers
SOURCE: Hard drive not recognized, making clicking sounds
Sorry to say: the last 4 times I got that little click-click-click sound, I ended up getting an Return Authorization from Western Digital and a replacement drive. They were under warranty. A friend of mine used to try some of this "Disk Doctor" software, but it seldom worked. I would contact the manufacturer (if you've had it less than the warranty period). Western Digital warranty period is 3 years - don't know about other manufacturers, but it seems reasonable that your could also be covered that long.
Posted on May 30, 2008
geokohler
  • 304 Answers
SOURCE: External drive seems to freeze up everything, including desktop when USB plugged in
Do not panic. The problem is with the controller in the external case and not the HD itself. Open the case and remove the hard drive. Bring it to circuit city or best buy and invest in a new HIGH QUALITY external case for your hard drive. An associate at either of these stores will be able to tell you the exact case you will need.(SATA,E-IDE,IDE,ect...) DO NOT BUY the cheapo $10 cases you can get on the net. There is a reason some cases cost more then others and the main reason is the quality of the internal components and the durability of them. Install Your HD in your new case(very simple) and you will be up and running in no time.
I Hope this helps you out and you appreciate my help enough to remember to rate me FixYa when you are all fixed up.
Feel free to contact me with any of your other technical needs,
as always my help is free...This is my hobbie...
George
Posted on Jul 19, 2008
  • 1121 Answers
SOURCE: USB Device Not Recognized...
try to the laptop firewire port, if works. I didnt find any support for youfirelite drive
Posted on Dec 29, 2009
  • 15 Answers
SOURCE: My smartdisk 40 gb portable drive that I have been
It's probably faulty - must be an old drive if only 40Gb,
Replace it with a new one.
Posted on May 16, 2010
lock123
  • 6831 Answers
SOURCE: I am receiving power to my external hard drive,
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Installing Operating System on New Blank Hard Drive
Did you partition the hard drive ? Make sure that it is compatible .Some HP computers will only allow you to use certain products and you can not upgrade\downgrade or change an operating system .Try going online on another computer and see if the devices in your netbook can be changed or upgraded. HP is big for "Thank you for your business & your stuck with it the way it is " I wish you luck .
Feb 06, 2014 | Intel Hp Mini 1000/1035...
Windows 7 on new asus 1018p netbook does not recognize
Welcome to Fixya. Is it possible to provide a brief explanation or provide a brief backgroud of the issue so that we can help you fix it. Which one is not recognize?
Thanks
Jun 17, 2011 | Computers & Internet
Have new drive Hitachi SimpleDrive Mini 250GB USB 2.0 Portable External Hard Drive SDM/250RW (Red Wine) and works fine on Dell precision M4300 laptop Vista OS with either one or two usb plugs (so no extra...
Most USB hard drives require an external (or secondary) power cable to power the devices when connected to laptop or netbook computers. In some cases, even older desktop computer models will require a similar cable.
This is due to the specifications for the USB standard as it dictates the amount of voltage that a USB port can deliver. Some USB ports are considered "powered" and are sometimes identified by the USB logo and a small "+" sign to indicate the added voltage.
Note: Not all manufacturers use this logo, so if your computer doesn't have this variation of the logo, it doesn't necessarily mean the USB port is not powered.
This added voltage supplies additional current to power smaller devices, such as portable (or 2.5") USB hard drives. However, in the even that the USB port is not powered, then only the minimum amount of current is supplied. This should be enough to slightly power the drive, but not sustain it, thus causing the clicking noise and there isn't enough current running through to move the arm that reads the data on the hard drive.
Chances are that the USB ports on your Asus Eee are not powered and won't allow your hard drive to run until either a secondary cable is purchased or if you use a powered USB hub instead.
The secondary cable looks a lot like a Y-USB cable with one end that connects to your hard drive and the other end consisting of 2 USB plugs that both connect to existing USB ports on your netbook. Between the 2 USB ports, they can draw enough current to power the hard drive - the downside being that if you only have 1 USB port you cannot utilize the cable or if you have 2, they will both be occupying the ports while the hard drive is in use. These cables can cost about $1-7 depending on brand and can be found online in retailers such as eBay & CompUSA.
The USB powered Hub is a more expensive solution, ranging at about $10-25, but is the higher recommended of the 2 solutions since it will provide its own power supply to the tiny device, will use on 1 of your USB ports and since it's a hub, they usually have anywhere from 3-5 additional USB ports (all powered) for you to use, if needed. Some even include built-in memory card readers and they do not require any additional drivers or software to install and can work on any desktop/laptop/netbook.
Aug 14, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
Brand new, not recognized by hardrive
Try plugging it into the back ports of your computer haven't already. The clicking is from the reading head not finding zero on the platter, which means its either a bad drive or a lack of power. So try the back ports first if you haven't already, because they usually supply more power than any front ports. It also depends on how old your computer is, but in general if it has XP on it it should have enough juice to power the drive.
Jun 25, 2010 | Hitachi SDM320BD 320 GB USB 20 Hard Drive
My new computer can not recognize my iogear GHD 335C external drive . I had it for three years, nothing happened to it . I hear a spinning disc noise . The lights on the drive are on and I can't remember...
first check the usb port of your new computer for which you are connecting the drive .The noise comes when the drive is read mby the system .Please try with different usb port and even then if it is not working there is some problem with the drive
Mar 07, 2010 | IOGear ION (GHD335C160) 160 GB Hard Drive
Delstar DS 700 won't read flash drive
According to the Delstar Manual you should always have the netbook pluged into aan ac outlet if you are going to use an external device such as a Flash drive which is powered from the netbook's usb port. Try this and maybe then it will recognize the drive and function.
Jan 11, 2010 | Computers & Internet
Toshiba netbook won't recognize LG GP08
If the drive is not self powered, it might not work because the USB port on the computer maybe does not have enough power to run the drive. Also, if the drive is USB 3.0, and the USB port on the computer is USB 2.0, it probably will not work. Good luck.
Jan 16, 2018 | LG SecurDisc 8x External Double-Layer DVD...
Toshiba 160 GB Hard drive is not seen by 'new' computer
I have had a similar problems with external drives that only plug into a USB port (no ext power adapter). It is very common that the power supply fed through the USB port is inadequate to power an external hard drive. Some enclosures have a external A/C input to resolve this. Also, some computers (motherboards) only have a select number of USB ports that are powered. Since this device is detected by your other computer and not on the new one, my next attempt would be to locate a USB hub with external A/C power. There is a good chance that this will resolve the problem. By the way, when you plug in the drive does it spin up?
May 03, 2009 | Toshiba 120GB USB 2.0 Portable External...
My computer stopped reading my external hard drive
Try the drive in a different USB port. If it still fails try another computer. If it still fails then it's possible the drive is bad. If the warranty has expired you may be able to find a tech savvy friend to remove the actual drive from the case and hook it up to another computer directly. If it recognizes fine then the case is bad. If it does not recognize the drive then the drive is dead.
You won't be able to retrieve the files on the drive unfortunately unless you use an extremely expensive service. These tend to run in the hundreds of dollars.
Nov 22, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hard drive not being recognized
dear ramroot
enter device manager by type devmgmt.msc, select universal serial bus (USB), you can see what problem at USB, right click to conflict port delete the port who's conflict.
restart your computer.
trying to connect your ext. Harddisk again
oke
cropp
Mar 17, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Open Questions:
SmartDisk 160GB FIRELITE PORTABLE FIREWIRE HARD DRIVE 5400 RPM 2.5IN 160 GB FireWire 400 Logo
113 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
