Question about Jl Audio 500/1 Car Audio Amplifier
My thermal light on my 1000/1 amp comes on too often
    Scholar:
  • 83 Answers
This means your amp is in "protect mode" this light indicates that your amp is having a short circuit or loose of power.
Check your cables, if they are secured & no exposed wire And most important of all, check your voltage reading, it must be above 12v.
Loosing voltage in car audio is the number1 factor of heat/thermal problem & fire.
When an amp looses voltage, heat builds up inside it. Too much heat will make the amp be on "protect mode", excessive voltage drop will cause the amp's circuit board & other parts to be burned.
So, always watch your Voltage, either with a plug-in volt-meter or with a fuse holder & voltmeter.
Hope this helps.
Posted on Apr 08, 2011
Why is jl audio 1000/1v2 in thermal but not hot?
They might be using the light to show other problems as well. Or the unit you bought has the same issue??
Double check all your connections, leave it unplugged for 24 hours after hitting the power button several times to drain the capacitors to hopefully clear any codes in the modual.
May 15, 2014 | Jl Audio 1000/1V2 Car Amp
I blew the fuse inside the fuse block (60A). I replaced it so now I know I have power getting to the amp. I checked it with a meter and I show 12 volts passing throught the fuse block. I can not get the...
Sometimes there is a fuse inside but they are usually thermal and reset when they cool. You said u blew a 60 amp fuse. Is that what the manuf reccomends? Check your remote turn on wire (blue) make sure u have power on the remote wire when you turn the radio on. only thing really left are the grounds
Jun 11, 2011 | Jl Audio 1000/1 Car Audio Amplifier
I have a Jl Audio 250/1 mono block amp and the thermal light keeps coming on what could be causing this?
It could be a number of things? 1 to many subs, speakers wired to the amp causing it to overheat and making the thermal light come on. 2 It all depends were your amp is. If it's clear and nothing covering it, obstructing it, Ie sub in front of it, amp inbetween the rear seats and sub.
Mar 04, 2011 | Jl Audio 250/1 Car Audio Amplifier
My amp will not power up
try hotting your remote wire to your batter if it don't come on u will need a new amp
Jun 14, 2010 | Diesel Audio NS-1000 Car Audio Amplifier
Ibm wheelwriter 1000 1 & 2 lights come on and
It sounds like a bad keyboard, you can try my tip under WW1000 or contact Geo. Beyers Co. for a keyboard rebuild @ 800-392-8085 tell them O'Reilly sent you.
DickyO
May 19, 2010 | Lexmark Wheelwriter 1000 Typewriter
Thermal light goes away when ground added
Doesn't sound like anything is wrong. If the thermal light is on before you have the ground hooked up then the amp is probably getting a small amount of electrical ground from the shielding on the RCAs or its mounting to the chassis of the vehicle allowing the amp to "barely turn on" (not enough ground). I can imagine this would make the amp think something is wrong (ie: thermal light) . May I suggest that you do not try to turn any amplifier on without ALL appropriate wires connected correctly.
Mar 01, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Ive lost my instructions to operate my P-T 1000 HELP
The following link is the instruction manual that comes with the device, http://www.scribd.com/doc/3568489/brother-PT1000
Hope this helps,
Joe
Feb 25, 2010 | Brother PT-1000 Thermal Label Printer
We have Alps MD 1000 which makes a grinding noise when we power it up, and then the error light comes on. Is this normal, or is what could be the problem? Where would we need to send it for repairs?...
All ALPS printers make noise when they are turned on. The error light is not normal. Do you have cartridges in the printer? there are two kinds: ones with gray plastic cassettes and ones with dark blue plastic cassettes. For the 1000, you want the gray ones. Are the cartridges installed correctly? Side B should be facing up.
Feb 06, 2010 | Alps MD 1000 Thermal Printer
Heat lamp for clc 1000
Heater lamp could be burnt out.
Heater lamp connections
Thermal fuse
Thermistor
Control board for the fuser.
May 01, 2009 | Canon CLC 1000 Color Copier
I have a Rockford Fosgate Puch 1000 watt amp "thermal" problem
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up without the thermal LED being lit, the wiring needs to be checked. If it still indicates that it's in thermal protection, it needs to be serviced. A local repair shop will be the quickest. Rockford will email you the schematics.
Apr 07, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Jl Audio 500/1 Car Audio Amplifier Logo
358 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
