Question about HP OfficeJet 6110 All-In-One InkJet Printer
Keeps saying remove and check cartridge and is terribly slow to mow print anything
    Scholar:
  • 83 Answers
Printer keeps saying alignment, load paper and press tick will not print anything off ?
It could be the cartridges are not seated properly in carrier. Try to remove any paper from the paper feed tray. Remove the cartridges from the printer. Then unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Try to print again.
Mar 08, 2011 | Lexmark X5495 Printer
Hp psc 2175 all in one keep saying remove and check cartridge
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 19, 2010 | HP PSC 2175 All-In-One InkJet Printer
Dell v305w Alignment Error
You should have the option to print an allignment page, try that.
Hope this helps!
Feb 05, 2010 | Dell V305w All-In-One R840635AU InkJet...
My 7410 keeps saying to add a black ink cartridge but i did
Remove black cartridge and check to insure the spring has not broken loose.
Jan 14, 2010 | HP OfficeJet 7410 All-In-One InkJet...
I put in new color and black cartridges a couple of days ago and was able to print okay. Now I keep getting ''Remove and Check Black Cartridge'' prompt. I've taken out Black Cartridge, turned off printer,...
hope you put back both cartridges before trying again..try wiping the tip of the black cartridge before replacing it..then activate the head cleaning process..
Oct 03, 2017 | HP G85xi All-Color InkJet Printer
Prints everything blank
Check the print cartridge. Open the printers top cover and find release lever for the ink cartridge. Lift out the cartridge and check the jets (copper coloered foil with holes) for blockage. New cartridges have a piece of tape over the jets which must be removed before installing. If blocked with dried ink, dab gently with paper towel and rubbing alcohol. Dry by dabbing on paper towel. Other things to check are: Incorrect cartridge, empty cartridge, and cartridge not snapped in all the way. The cartridge that comes with the printer usually is only partly filled and runs out earlier than normal. You could always try a new cartridge which you will need eventually anyway.
Good luck,
Techjoel
May 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer won't let me do anything
Must have ink in both balck AND color cartridge for the 6210 to function. Period. No way around this, as designed by HP.
Feb 04, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Not printing
did you remove the safety tape from the cartridge ?
Dec 23, 2008 | Office Equipment & Supplies
Lexmark 2400 has message saying clear carrier then press start
Good day Sir, Please check the power switch light if blinking.
  • power light blinking slow - printer is out of paper.
  • power light blinking fast - there is paper jam in paper.
  • once, pauses and blinks again - raise the scanner unit, and remove any objects blocking the path of the printer cartridge carrier. Or the print cartridge is missing/ not installed properly. Or the printer cartridge is not the correct type for the printer.
Have a nice day.
Nov 22, 2008 | Lexmark X1240 All-In-One InkJet Printer
Align Print Cartridges
A simple question first - have you removed the protective tape from the bottom of the cartridges? What kind of printer is it? I suggest you unplug the printer for a few minutes and then try again. Are they the manufacturer's cartridges or a lower cost brand? If they are the latter, it's possible they won't work with your printer.
Aug 05, 2008 | Tablets & eReaders
HP OfficeJet 6110 All-In-One InkJet Printer Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
