Question about IP Messenger
I want to add my friend...I have added his ip address but still is not being displayed
    Guru:
  • 811 Answers
It may not be accessing the IP for you friend you may want to use his or her email or username for messenger instead of his or her IP I have not ever heard of using a IP address to add a friend. I could be wrong here. Thanks for using FixYa! John
Posted on Apr 08, 2011
Adding ip address
You cannot add it manually...you can switch OFF and ON the device and again try the internet source like Wifi etc...If it gets connected..visit Ip-details.com and get the Ip address.
Jan 06, 2014 | Tablets & eReaders
Trying to port forward a web port, media port, and phone port to an ip address for security camersa
1. Select Port Forwarding/Port Triggering under Advanced in the main menu.
2. From the Service Name list, select the service or game that you will host on your network. If the service does not appear in the list, see the following section, "Adding a Custom Service."
3. In the corresponding Server IP Address fields, enter the last digit of the IP address of your
local computer that will provide this service.
4. To the right of Server IP Address, click Add. The service appears in the list in the screen
To define a service, game, or application that does not appear in the Service Name list, you must first determine which port number or range of numbers is used by the application. You can usually determine this information by contacting the publisher of the application or user groups or newsgroups. When you have the port number information, follow these steps:
2. Click Add Service (see Figure 5-1 on page 5-7).The Ports-Custom Services screen displays.
3. In the Service Name field, enter a descriptive name.
4. In the Service Type field, select the protocol. If you are unsure, select TCP/UDP.
5. In the Starting Port field, enter the beginning port number.
• If the application uses only a single port, enter the same port number in the Ending Port
field.
• If the application uses a range of ports, enter the ending port number of the range in the
Ending Port field.
6. In the Server IP Address field, enter the IP address of your local computer that will provide
this service.
7. Click Apply.
See the rest of the manual here.
http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf
Dec 26, 2013 | NetGear WNR2000 Wireless Router
When i open my internet it scroll very slow so i open my LAN connection using Realtek RTL8168D(P)/8111D(P)PCI-EGigabit Ethernet NIC and open its'properties and click the box repair and suddenly a...
Hi
The Address Resolution Protocol (ARP) is very crucial for TCP/IP network communication. If you begin to notice network connectivity problems such as particular web pages not loading or not being able to ping certain IP addresses then clearing your ARP cache is a good place to start.The TCP/IP ARP Command component provides the functionality to add, delete, or display the IP address for Media Access Control (MAC) address translation.
To flush/Delete the ARP cache in windows 7/Vista/XP/2000/Server 2003/2008 follow this procedure
Click on Start->Run-> type the following command click ok
netsh interface ip delete arpcache
Dynamic ARP cache entries update persist for 2-20 minutes depending on the system.
Windows 2003 Server = 10 minutes
Windows 2000 professional/Server = 10 minutes
Windows XP = 2 minutes
Solaris = 5 minutes
Delete IP address using arp command
arp -d <ip address>
Example
arp -d 10.1.1.2
Display arp table
arp -a
Add static entry to ARP table
arp -s <ip address> <mac address>
Example
arp -s 157.55.85.212 00-aa-00-62-c6-09
Jun 21, 2011 | Nvidia Computers & Internet
How do i chang the ip address on my cannon IRC3170? or set it to automatic so that my computer can find the printer on the network??
After complete installation of printer
1. Go to control panel-> Device and Printer
2. select printer which you want to set an ip address and right click and select printer properties
3. It will display on general, select port tab
4. select the printer
5. Click Add port
6. it will display a printer port
7. Double click the standard ip address
8. click next and change the ip address
9. finish
Mar 19, 2011 | Computers & Internet
How do I change the ip address from the lcd display?
hi
  • Go to the Control Panel from the Start menu.
  • Step 2 Click "Network and Internet" and then "Network and Sharing Center."
  • Step 3 Click "Manage network connections."
  • Step 4 Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
  • Step 5 Click the "Networking" tab.
  • Step 6 Choose either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6).
  • Step 7 Click "Obtain an IP Address Automatically" to reset your IP address automatically, then click OK.
  • Step 8 Click "Use the following IP Address" to enter your own IP settings.
  • Step 9 Enter your IP address into the boxes marked "IP Address," "Subnet Mask" (or "Subnet prefix length for IP/TCPv6) and "Default gateway."
    Change your DNS Server Settings
  • Step 1 Click "Obtain DNS Server Address Automatically" and then click "OK."
  • Step 2 Click "Use the following DNS Server addresses" to change your DNS Server settings manually.
  • Step 3 Type your primary DNS Server address into the box that says "Preferred DNS Server."
  • Step 4 Type your secondary DNS Server address into the box that says "Alternate DNS Server."
    Add a New Network Protocol
  • Step 1 Click "Properties" and then "Install" from "Manage network connections."
  • Step 2 Click "Client," "Service" or "Protocol," depending on which you wish to add. Then click "Add."
  • Step 3 Select the item you want to add from the dialogue box and click OK.
  • Jul 02, 2010 | Zebra Printer 140-751-00000
    How can I configure an ip address in the printer?
    As far as adding in an IP printer with XP, it is fairly simple.
    Control Panel / Printers
    Add Printer
    Local (No automatic detect)
    Create a new port
    Standard TCP/IP port
    Enter in the IP address of the Printer
    Then add in the drivers when requested.
    Your problem will be solved.
    Thank You
    Aug 06, 2009 | Gestetner DSm415f All-In-One Laser Printer
    Adding IP addresses to a HP 5550 DTN printer
    ok then install that printer as a network printer to one pc share ti and ad to as much pc you need after that without ip adress
    Dec 10, 2008 | HP 5500 Color Laser Printer With Internal...
    Ip address of hp deskjet d4160 to add printer in network
    For getting the IP address, first you have to check printer settings from printer LCD display panel. Or alternatively you can search for network connected printers and then install it.
    Nov 22, 2008 | HP Deskjet D4160 InkJet Photo Printer
    Computers & Internet Logo
    202 people viewed this question
    Top IP Messenger Computers & Internet Experts
    David Payne
    David Payne
    Are you an IP Messenger Computer and Internet Expert? Answer questions, earn points and help others
