Question about Radio Shack Pro-96 Scanner
I have a problem with the wx priorty check staying on and it keeps me from hearing transmissions how do i shut off.
    President:
  • 2,761 Answers
According to manual you can deactivate the Priority function by pressing the PRI key while the scanner is powered ON. Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.freqofnature.com/resources/reviews/manuals/pro96.pdf
Bill B.
Listening in since the 60's
Posted on Apr 09, 2011
Water not going into well water tank
Is the pump running when power is ON?
Put ear against pipe and listen for pump.
Have you installed a check valve?
Check vlave lets water pass through the pipe and enter tank, but the valve closes after pump shuts off and keeps water from falling back down into well.
Aug 23, 2014 | Amtrol WX-302 WX-302 150S1, 86 Gal...
What does blinking pf mean
This means 'Power 'Failure'.
This could be from the circuit breaker being tripped and then was reset, wall outlet issue, or possibly if the cord was replaced then the screws conecting the wires to dryer may not be tight. Make sure dryer in unplugged before checking connections.
Some homes have an energy management system where higher energy use appliances are given a priorty so they all cannot run at same time so keeps your electric bill lower.
For example, the water heater and a/c system would be wired to override the dryer so if both these were runnng and then you turned on the dryer, the control unit would shut power down to dryer within a short time.
Hope this helps.
Jun 27, 2014 | Kenmore Elite HE4 Electric Dryer
I have an almost new Midland 75-822 that the WX works fine on, but the CB doesn't seem to receive, or transmit. It operates normally, but no reception, and no evidence of transmissions.
you'll need a schematic and some knowledge. there a two diodes that control the rx and two that control the dx.Check them to make sure they are producing the correct power out put if they are not you should replace all 4
May 10, 2012 | Midland 75-822 40-Channels Handheld CB...
My cb is on and i can hardly hear it, the volume is all the way up and i've adjusted the squeltch also any ideas?
check swr's, if ok. those 18's 19utras and wx radios have small vertical boards that get loose and will cause them to either loose TX or RX sometimes both.. they need to be taken out resolderd and 99% of time is the fix.... other probs, bad speaker. or broken mic wire.. check with another speaker and another know good, mic..
Feb 05, 2011 | Cobra 18 WX ST 40-Channels Base CB Radio
My model hlp 4674 wx/xaa sceen won"t do anything
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
I am able to transmit but not able to receive on this model and the squelch is very low, can you help me resolve? I am not receiving any weather transmissions either.
Hi, my name is John. Check your antenna that it is getting a good connection,and that it is grounded. Turn your RF GAIN to MAX. Turn squelch all the way to the left. To hear Weather, Press the Weather button. hope this was very helpful.....rate this solution on the four thumbs-up.....John
Sep 08, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
Cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
May 29, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
When scanning the radio resumes before end of transmission
The manual states that the scanning will halt whenever the squelch is broken by a transmission, just as expected. When the transmission is complete, the radio continues scanning. This makes hearing any reply nearly imposible to monitor - and is the problem I believe you are describing.
Page 37 of the manual says that a 2 second delay can be assigned to a frequency whenever the radio has paused on a channel. Simply press the DELAY key on the scanner to assign the delay to the channel. If there is no additional transmission within 2 seconds, scanning will resume.
Below is a copy of the manual to reference or print if you can't find yours (you'll need a free program called "Adobe Reader" found at www.adobe.com to view or print this manual).
http://www.uniden.com/pdf/bc898tom.pdf
I hope this helps!
Oct 30, 2009 | Uniden BC898T Base Scanner
Cobra 75 wx st everything seems to work eccept receiving signal meter will spike on trx and it seems to receive but no sound there is sound in wx mode
WX is for weather. If you put it on WX, and you do not hear anything, then you need to change the weather station it is on. in wx mode, you change weather channels by pressing channel up and down. To communicate with 2 way, press the cb/wx button so it is on CB mode.
Sep 28, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
No sound
Its, either a broken wire in the mic or the internal speaker blew. Try an external speaker then the mic
Jan 24, 2009 | Cobra 18 WX ST II 40-Channels Base CB...
Radio Shack Pro-96 Scanner Logo
56 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
