When i plug my Sony USB2.0 in the drive there appeare the following" THERE IS NO DISK IN THE DRIVE. PLEASE INSERT A DISK INTO DRIVE."
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Posted on Apr 08, 2011
Sony HD-EG5 is not detected on my laptop
Download the "password protection manager" software from the Sony website. When installed it will detect your Sony External hard drive.
Jun 13, 2013 | Sony 500gb External Hard Disk Drive, Usb...
Cannot access documents on remote diskette drive
ok this is definitely 1 of 2 problems.
1.) the diskette drive is damaged..
2.) the disk them selves are bad. These disk dont last very long and develop a white fungas on the magnetic disc itself.
to be certain get a disc you are re is working ,, and try it on a machine with a drive for it (dont know if they still exist).. if the disc works and does not work on your machine get a new drive..
if the disc don't work well then they are bad.
Dec 29, 2012 | IBM Wheelwriter 70 Series Ii Typewriter...
F:/ drive does not read Scan Disk device
Try inserting the memory card into an USB card reader and then plug it into a different computer. If this computer does not detect the memory card then the memory card is probably faulty.
May 21, 2012 | Sony VAIO VGN-SZ320P/B Notebook
Have disk in drive E but computer says "Please
try to put some cd lens cleaner if you have a previous cd cleaners you can use it
Aug 03, 2011 | Acer (KV.16X04.007) DVD Drive
I have a kingston datatraveler dti g2 with 4gb capacity. when i insert it it displays as "Removable Disk (F:)" but when i clicked it the message "Please insert a disk to drive F". my os...
Solving this program is simple. Your BEST option is to contact Kingston directly:
http://www.kingston.co,/support/default.asp
Answer the questions on that page and follow the prompts to get help from Kingston. They will know how to help you solve this problem at no cost. They will tell you how to test the flash drive to be sure that it is still working properly. If the drive is defective, they will issue you an RMA number so you can return it for a new one. Kingston support is excellent; contact them and they can help you solve this.
Good luck; let us know how this turns out.
Apr 14, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
The status of the drive shows "device working properly". But whenever I insert a CD and press Play, a message saying "Please Insert a Disk" appears on the screen. Please help me out...
clean the lens, try another CD.
If neither of these work, the laser is likely gone, and you'll have to replace the drive.
Oh, lens cleaning...GENTLY wipe with a q tip with rubbing alcohol on it.
Feb 24, 2011 | Mitsumi SR244W Plug-In Module 24x CD-ROM...
Getting "update.exe - No disk"
This issue occurs when all the following conditions are true:
• You have a removable drive configured as drive letter C.
• You do not have a removable disk in the removable disk drive.
To resolve the issue, use one of the following methods:
Change the drive letter assignment for the removable drive to a letter other than C.
To change the drive letter assignments in Windows 7, follow these steps:
1. Log on to the computer as Administrator.
2. Insert a disk in the removable drive.
3. Click Start, right-click on Computer, and then click Manage.
4. Click Disk Management.
5. Right-click the partition, logical drive, or volume that you want to change, and then click Change Drive Letter and Paths.
6. Click the removable drive, click it, click Change, click the drive letter that you want to use, and then click OK.
Feb 01, 2011 | Computers & Internet
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Feb 13, 2009 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
