Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Hello i have a kenmore side by side refrigerator model #253.5696360 it stop making ice, & ice buildup on back mid/lower panel. i took panel off it was frozen up, i defrosted it turn on 1 & it's freezing up again & no ice. please help!
SOURCE: Refrigerator freezes up
turn off
take all food out.
open door of freezer.
let all ice melt away.
remove cover over evaporator coil.
turn on.
should hear fan running.
if it doesn't, hot wire it with 110 v.
if fan no works with hotwire, replace fan.
if fan works with hot wire, find evaporator thermostat about 1 inch big
clipped on coil of evaporator.  short out ( put wire connecting its two wires ) .
if fan runs now, replace evaporator thermostat about $ 15
Posted on Oct 23, 2007
applianceboy
  • 77 Answers
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Posted on Sep 26, 2007
fridgetech
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
fridgetech
  • 473 Answers
SOURCE: Ice is not ejecting
Sounds like the icemaker thermostat is opening too soon which turns the heater off.  The easiest thing to do is replace the whole ice maker which I have seen pretty cheap on ebay.  If you want you can test these part with an ohm meter.  Check the heater for resistance.  If it is ok then replace the module and thermostat.
Posted on Oct 26, 2007
SOURCE: Water leaking inside refrigerator
Its the clogged defrost drain. I have the same problem. I just cant find the drain
Posted on Jun 07, 2008
Kenmore Refrigerator Elite Mod # 106.55602400 is not making ice
Is the food frozen solid in the freezer? Does the ice maker get any water to it? Do you see any ice buildup in the freezer?
Jan 19, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore coldspot model 106 9445781 the icemaker motor makes loud noise. Sounds like its under a heavy load.
Suggest you take the ice maker out and defrost it. You propably have ice crystal buildup and causing it to labor harder.
Jan 16, 2012 | Kenmore Side by Side Refrigerator
Will not make ice
The ice maker has completely stopped producing ice.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 29, 2010 | Whirlpool GS6NBEXR Side by Side...
Iced up in the lower freezer side, took panel off
Sounds like a defrost problem. Is the model MSD2756G your model number? Let me know, Sea Breeze
Jun 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Good Afternoon: Icemaker on my side by side GE refrigerator all of a sudden start making a loud noise this morning and has not stopped since. There is evidence of ice buildup under the icemaker. Can...
Hello: I have solved my problem for right now. I defrosted the ice buildup under the icemaker applying hot cloths until the ice dissolved , after the ice fell, the noise immediately stopped. In the past two days so far the everything is running smooth. Thanks so much!
Jun 04, 2009 | GE GSS25JEMWW Side by Side
Oct 10, 2007 | Kenmore 53542 / 53544 Side by Side...
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
64 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
