The air coming out from the blower is not cool, even though the aircon switch is on.
  • 413 Answers
Compressor may not be running. Make sure your thermostat is turned to cold
may be low on refrigerant
Posted on Apr 08, 2011
My Nissan Almera 2005 Model keeps blowing heat even when the switch is off. now when l turn on the aircon hot air is mixing with cold air. Could it be the blower resister?
Could be the diverter paddle control that moves to allow cold air or hot air into the duct. It may be staying in the heat position even when you set the control to cool.
Jan 02, 2015 | Nissan Cars & Trucks
Bonaire vulcan evaporative air conditioner
check your filter for dirts, clean or change it, check your evaporator and condenser coil and clean....
Jan 29, 2014 | Heating & Cooling
I installed an RTH2300 this winter to replace an old mercury thermostat. It worked fine for the heating season. I turned it to Cool for the first time today and my AC and furnace blower will not turn...
Maybe turn selector switch to off.see if every thing shuts off.if yes. turn FAN selector switch from (auto) to (on) mode.does the outside unit come on or does just the furnace blower only run ? the inside fan should be the ONLY thing on.if not, reverse the (G) & (Y) wires inside the new thermo.
Jun 07, 2011 | Heating & Cooling
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
I purchased my convair aircon in 04/08. It has been in storage and I have only just started using it. When cooling it starts to cool then starts beeping and has E1 on the display. this can only be...
E-1 Indoor blower motor mechanism locked or Indoor sensor problem. Rotate blower wheel manually. If not rotate, replace bearing. If motor good, replace sensor.
Jan 03, 2011 | Convair Heating & Cooling
Why is my heater not working in my ford focus. all fuses are fine?
If it doesn't blow at all, and/or you only feel a small amount of air coming through the vents (not forced), it may be the blower motor switch.
Sounds as though the fan motor could have failed (the noise), if you have fitted a new resistor pack and the fuse is OK, probe around with a multi-meter tracing the supply (12Volts to ground) through switch to the fan. The heater/aircon blower is fuse 64 - 30amp (if I dont mistake). If the motor itself is shorting out then this would blow this fuse. Try a 12v feed direct to the motor terminal and see if it works.
Hope this helps.
Nov 30, 2010 | Ford Focus Cars & Trucks
My LS-H186 VML 1Metal Art Cool 12000 BTU Air Con does not heat up
You should also check the outside unit to make sure the coil is not clogged with dirt or grass clippings and the fan is working. The reversing valve that switches it from cool to heat could also be a problem. If it isn't shifting it will not switch between heat and cool.
Apr 29, 2010 | LG Art Cool LA181CNW Split System Air...
Aircon not blowing through dash vents
If it blows thru other vents, your air ducts may have come loose. If you don't get any cool air, your coolant is low (it evaporates during the time and below some point it will not circulate anymore). Also the aircon blower can be faulty.
Dec 03, 2009 | 2005 Hummer H2
My KOLIN window type remote control AIRCON is building up ICE
If you already had the coils and filter cleaned and the blower is OK, that only leaves the refrigerant charge.
You are probably low on refrigerant.
Jul 26, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
