Question about RCA D52W19 52" Rear Projection Television
RCA D52W19 TV. While moving to my house tinted outer screen/lens was sucked out by wind and "removed". The clear inner lens is fine with no scratches visible nor to the touch. What part number is this screen and is it difficult to replace? I have good mechanical skills and have some electronic experience. Thanks!
  • 1 more comment
  • Ta2boy Apr 08, 2011
    The tinted screen that covers the main large clear screen that the image is shown on when watching.
    Any idea what RCA part number that would be? The website that was linked in the previous answer doesn't include shipping BEFORE I checkout and doesn't give me any idea how much that amount will be. Not gonna happen from them.
    Thanks for providing me with the info about the Super Screen and part number.
  • 325 Answers
You will need to analyze if you need the outter most screen or the set of screens. Hopefully you can get away with the outter most screen as it is quite cheaper.
To replace the screen is VERY simple, however you will need at least one helper to square it up properly. As long as when it was "removed" it didn't do too much damage to the mounts.
Hope this helps, the screen prices are in the hyperlinks above!
BEST OF LUCK! Please rate!
Posted on Apr 08, 2011
  • 1 more comment
  • Andrew P.
    Andrew P. Apr 08, 2011
    Also, make sure you are in a dust free environment for screen replacement. You don't want particals of dust inside your screen (the dust will drive you crazy if you let it in your screen)
    Thanks again,
    A. Palmer
  • Andrew P.
    The outter most screen part # is 258797
    Screen set part # is 258513
    Thank you
  • Andrew P.
    Not a problem! best of luck to you!~
  • 4,889 Answers
Are you refering to the primary screen that the image is projected on or the mirror screens near the lens?
  • eagle338
    eagle338 Apr 08, 2011
    Aaah thats the super shield AKA anti-glare screen, also serves as screen guard as you have seen. You can purchase it here for 85$. Since you have already disassembled most of the tv to get to the lens this should not be hard for you at all. However if you do get stuck somewhere let me know. You just have to remove the screws holding the screen assembly and a few clip kind of things that lock themselves to the chassis
    http://www.ued.net/ued/addItems.do?itemC...
  • eagle338
    RCA part number for a supershield? This part is usually manufactured by third-parties and installed by RCA. With the set being rather old I doubt whether you can get it from RCA. Besides they are an authorized distributor so its like you are getting it from RCA. They have given a couple of phone numbers for you to call them at
    (800) 648 - 6657
    (708) 946 - 9500
    PS: I could locate the part anywhere else. I can only wish you goodluck finding it somewhere else.
I have the model D52W19. I have two TVs in the house one works fine and this RCA model is a problem. The set usually turns on OK, then it begins to snap and pop. The screen will go black for either a few...
the small signal board would be suspect on that model. Depending on the bar code number which is on the small signal boards sticker you may find a replacement board at www.tvrepairworld.com for your model.
Aug 31, 2011 | RCA D52W19 52" Rear Projection Television
The screen on our 52 inch TV needs cleaning-inside and out
The outer screen is a protective screen. it is just glorified plexiglass. just use a soft cloth slightly damp.
Apr 09, 2009 | RCA D52W19 52" Rear Projection Television
Projection on the screen is too large so the pic is cut off
using the right or left arrows should change your screen sizes 16.9 4.3 and so on
Jan 11, 2009 | RCA D52W19 52" Rear Projection Television
Replacement screen for RCA d52w19
You will need the entire model number to see if the screen is avalible.. D52w19 + the ext number YX1 or yx2 or something like that it will be on label as model number but in smaller letters.
Nov 20, 2008 | RCA D52W19 52" Rear Projection Television
My rca d52w19 has a cracked screen,
is the inner screen damaged? or just the outside. the outside is called the super sheild. this can be purchased at union electronics
Oct 07, 2008 | RCA D52W19 52" Rear Projection Television
Green Screen
Do you just have a completely green screen, or can you see a picture or On Screen display when selecting inputs and channels? And did this problem develop after moving the set "with great care"? Knowing RCA's reputation for building sets that develop intermittent connections after a few years, I would be tempted to look there first. Semiconductors and IC's have been very reliable lately.
Dec 28, 2007 | RCA D52W19 52" Rear Projection Television
CRACKED SCREEN
the outer screen on these units easly replaced. RCA #258797 their called supersheilds.. rca charges about 70 dollars for the item...If it is just that i have seen people just use a clear sheet of plexi. removeing the screens requires removein several torx 20 screw around the outer and remove the frame.. then the clear peice of plexi is attache with serval brackets.
Dec 25, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Scratched tv screen
I replaced the screen on my 62 inch projection TV for about $50 and the the picture quality is good! Have a sheet of plexiglass cut to the EXACT size needed. BEFORE installation it MUST be frosted on both sides by either a fine particle sandblaster or by sanding it VERTICALLY on BOTH sides with a power sander and a fine grade paper.
If this is only an OUTER protective screen and the image is projected on the inner screen then DO NOT frost the replacement screen, just install it.
Mar 18, 2006 | RCA P61927 61" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
152 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
