Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
What is the Thermistor on my LG Dishwasher LDF6810ST?
    Guru:
  • 500 Answers
It is the Sensor attached to the Water heating compartment (Element) on the Dishwasher.
It is attached to the Circulation pump.
See below image (It is the part in BLUE)
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up will do nicely too :-)
Posted on Apr 08, 2011
4 Suggested Answers
SOURCE: I have a LG LDF6810ST dishwasher with a tE error
Follow up to previous post.I replaced my sum seal and other nec. gaskets and reassembled.The TE code is gone and dishwasher performs as designed.I hope this helps someone with one of these POS dishwashers.Thanks
Posted on May 29, 2009
Krazytech
  • 725 Answers
Check the temperature. (Test Mode) If the temperature is displayed, adjust the Inlet Water Temperature to 120 . If the temperature is not displayed, check the wiring connection. check the electric resistance of Thermistor. (11~14k at 77 ) Replace the PCB.
Posted on Sep 27, 2009
buffalonyman
  • 1865 Answers
SOURCE: I have an LG dishwasher model 6810ST that comes up
LE means ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
You'll have to disassemble the unit and make sure nothing is stuck in the pump or locking the blade.
Otherwise you may have a loose wiring connector
Posted on Nov 16, 2009
LG dishwasher LDF modle 7811st error code tE just gives erroe code will not start.
TE error code means Thermistor Fault or Inlet Water Temp too High.
Check the resistance of the thermistor (located on the bottom of the unit in between 2 orange wires with single spade connectors which is the heating element) and it was good 11.7K ohms at 71 degrees room temp. Take the front door off and trace wiring. There is a white plastic wire loom and approx.6" up check the wiring being melted in the black mastic. The thermistor wiring is red and dark blue.
Generally, some lose or broken wires cause this. Keep us updated.
Jun 27, 2011 | LG LDF6810ST Stainless Steel Built-in...
I have a loose handle on my lg ldf6810st dishwasher. Can I remove the inside of the door and tighten it?
I think these have set screws located at the bottom of the handle on the outside of the machine..
Best regards
Ck
Mar 06, 2011 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher will not run and its showing a code of tE. Any idea what the problem might be ?
The thermistor is located between the terminals of the heater and comes as part of the heater assembly. You will need to pull out the entire dishwasher to replace it. The heater assy is stuck into the side of the sump,you can access it from the bottom of the d/w once ou have it out. The only source of parts in the US I know of is LG in Huntsville AL.
Aug 27, 2010 | LG LDF6810ST Stainless Steel Built-in...
Water leaking from bottom of door-LG LDF6810ST while dishwasher is washing dishes
could be door seal .or some time use the right dish soap, door may d need ajusted
Apr 11, 2010 | LG LDF6810ST Stainless Steel Built-in...
I have a LG Dishwasher model LDF6810 and it has an error code te...thermistor. Can I fix this?
Check the thermistor before you change it it can also be the PCB...
Aug 29, 2009 | LG LDF6810ST Stainless Steel Built-in...
I have a LG LDF6810ST dishwasher with a tE error. I've checked the resistance of the thermistor. It reads 17k @ 65 deg , a little higher than the listed range of 11-14. Is this ok? Is the thermistor...
Aug 23, 2009 | LG LDF6810ST Stainless Steel Built-in...
I have a LG LDF6810ST dishwasher with a tE error code. The service manual says check the wiring, the thermistor, and as a last resort, replace the main PCB. Where is the thermistor? Can I check the...
May 06, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
221 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
