Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
P4 chit overheating
I bought a bare bones kit, assembled it and booted it. Everything runs fine except for the fact that the CPU starts burning up immediately and my computer will shut down after 2min. Also from when i turn the computer on the data light comes on and stays solid. What could be my issue?
  • 4 more comments
  • XDeadSmurfX Aug 06, 2008
    Yes i accidentally opened up the chat again in a new tab and when i closed the extra tab it ended the whole session! But i will get the HSF, by the way any particular recommendation for one? i dont know much about them and yes this is going to be a gaming rig/media center so i want something good. also is there a certain size or anything that i am looking for?
    One question i have for a HSF is i believe my CPU is a socket 775, is that correct?
  • XDeadSmurfX Aug 08, 2008
    I bought one before i got your post because i wanted to have it before the weekend, so what i got was this it seems to be good, at least for now. What do you think?
    So i got the HSF installed fine, perfect fit easy install. booted up, everything is going fine. I start installing vista, ran fine for 5-10min i get up to go to the bathroom and i come back to the blue screen of death.
    Now if i restart, enter in my country and region info to the install program and hit install it says please wait for about 10 seconds then goes back to the blue screen.
    Details:
    "A problem has been detected and windows has been shut down to prevent damage to your computer.
    IRQL_NOT_LESS_OR_EQUAL
    If this is the first time you've seen this stop error screen... (Im sure you know this screen) ...
    Technical information:
    *** STOP: 0x0000000A (0x029EF970, 0x00000002, 0x00000001, 0x894ac557)
    I hope you can help with this!
    Thanks
    Ian
    So i pulled out one of the memory sticks out and tried installing again and everything worked.... Curious, why did that make it work?
    So i finished installing windows, turn computer off and added in other memory stick, and it works beautifully!! Thanks for all your help, it feels really good to have this computer working now.
    next on my list is adding a nice graphics card and then picking up a nice new game and controller and its time to let her rip!
    Brigadier General:
  • 6,966 Answers
Hi again,
For some reason I lost you in the Live Session/Chat.
In any case, my other thoughts:
  • The Intel 865 motherboard will auto shut down if fan does not rotate or in your case no fan. Added to this would be the thermal protection under the CPU.
  • The data led continuously lighting up is because of the jumpers.
Other than the above, I firmly believe, the unit will run as expected soon as the HSF (heatsink and fan) are installed.
My compliments, with the 2gb ddr from Kingston memory, i think you have a fast machine there. Just add a decent 128 or 256 (or even a 512) video card and you are set with a gaming rig.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 06, 2008
  • 4 more comments
  • Louie  Role
    Louie Role Aug 06, 2008
    Saw your added comment. Sorry, once the chat is closed no way to continue. However, you can still post here and we can carry on thereafter.
    Cheers.
  • Louie  Role
    Most heatsink/fan combo would work, but if you are intending to use it as a gaming rig then the better cooling the better. Some nice ones are:
    but the stock fans will do for most requirements.
    The only technical limitation is it must fit squarely on the CPU and be locked in place by the slots/clips, physical.
    Of course, pls put on some thermal paste.
  • Louie  Role
    yes it is a socket 775.
  • Louie  Role
    Louie Role Aug 08, 2008
    It appears to be identical to the original/Intel supplied heatsink but with a bigger/better fan. If it seats flat on the CPU and matches the 4 locks/tabs, then it should work out right.
  • Louie  Role
    Pls try:
    • run/install with only one of the memories;
    • swap/interchange the memories;
    • redo clean fresh install of the OS;
    • do a reset again of the motherboard CMOS/BIOS.
    Cheers.
  • Louie  Role
    hmmm, why did it work with only one memory?
    • Without knowing the exact model number, BIOS version and production version of the motherboard, I can suspect that 2 X 1 Gb is pushing it to the limit. It might still work but perhaps, a BIOS flash would be needed to the latest update;
    • the other memory is below specs and does not match up to the other. A way out is to lower the memory speed so both would work on the speed that the questionable one is capable of;
    • factory defect?;
    • might not have seated properly, try switching places.
    Am glad that it now works.
Computer wont start, despite all components working, cpu looks corroded
Pat,
Usually you diagnose these by process of elimination. Get down to the bare bone mobo without anything but the processor, good RAM (switch out if you can with different ones), and Power Supply. Eliminate everything else, no cd, no floppy, no hdd, no video cards, no sound cards, no cards at all really.
More than likely it's a bad power supply. Take the power supply to your local computer shop and they should test it for you for free... don't let them charge you for it. If it's good then test the cpu.
Hope this helps :)
Sep 22, 2013 | Compaq Computers & Internet
My asus Essentio CM5540 wont start, at all. all the cords are plugged in and everything looks right.
Bare Bones usually means stuff is missing, like the CPU, RAM,. Bare Bones would be a case, Power supply, DVD ROM, and little else. What is inside please.
Nov 18, 2010 | ASUS (r) Vintage-AE1 Desktop Barebones PC...
PC won't boot after upgrading cpu
either you have bought an incompatable chip for the mother board. or your power supplie is not powerfull enough I know this sounds stupid but it happened to me when I upgraded to a P4 3.6 quad core I installed the lot and it wouldnt start up I had a good power supply too Get your self at least a 500 watt PSU
Hope this helps
Apr 20, 2010 | VIA P4MA Pro Motherboard
Screen freezes and shows lots of lines - must restart everything. This is happening more often.
This can be memory, CPU, Hard drive, or graphics card, or overheating.
To check the memory, hdd, and cpu you can download the ultimate boot cd UBCD Burn it to a disc then boot to it. Use the utilities on it to test your components.
To check and track your temps you can download HWMonitor keep this running until it crashes. Once it does, reboot then open it again. The program will show you the max that the cpu and gpu reached in temp. gpu ovr 60C is usually starting to overheat. CPU over 50-60C (unless its a core 2 duo or quad then its 80C) is overheating.
To help solve overheating buy a cooling pad and have the thermal paste/pads replaced on the cpu and gpu.
If the problem persists then there is a big possibility that your gpu is heating up to much and the motherboard is starting to lose the solder joints to it.
Feb 22, 2010 | Toshiba Satellite M300-ST3403 Notebook
I have a AcerPower FH P4 -- 100% CPU usage all the time prob...
Boot your PC into "Safe Mode" (tapping the F8 key on boot to get to the option) and run a full/complete Virus scan with Anti Virus with up to date virus definitions and see what that yields.
Feb 09, 2009 | AcerPower FH - P4 631 3 GHz (S6463624) PC...
No boot up
Try removing all memory except one board. If it does not come up switch boards. Still no luck, check power supply if you can or switch it with another. A power supply checker is pretty cheap, 10 to 15 dollars, and well worth the investment, although it is not foolproof. Try switching PS off, physically remove the BIOS backup battery, then replace it and try again. That should have cleared the BIOS back to factory defaults. It sounds like a memory problem, but as a last resort, you might reseat the CPU. The CPU fan runs, yes? Can you get some other memory to try? Well good luck!
Sep 25, 2008 | ASUS A7V333 Motherboard
No display, but cpu fan works
maybe ur mobo is shot.... do u get a burning smell from it
Aug 27, 2008 | ATI RADEON X1650 Pro, (512 MB) PCI...
Central processing unit for Gateway computer
For a couple of hundred dollars you can get a much faster bare-bones desktop or tower and mb cpu combination and move your hardware to it. Upgrading your 450 isn't worth the trouble though jumpers on the board should handle upgrades to maybe 600MHz.
Nov 02, 2007 | Gateway 450SX4 P4-M Notebook
Laptop problems after changing cpu
Are you sure the CPU is compatible with your notebook?  What kind of notebook do you have?
Oct 18, 2007 | Toshiba Satellite A35-S159 Notebook
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
85 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
