Question about Intel DG965RY Motherboard
Sir, My PC is starting problem, 1.Starting UPS - ON the system starts automatically without swith ON. 2.After Starting the keyboard & Mouse get stuck 3.after Restart the the keyboard & Mouse Starts Please send me solution
  • 1,606 Answers
The UPS may not be sufficiently stable on power-on to run a PC immediately.
Try going into the BIOS setup after the restart and look for the option that has the computer "Start up automatically after power failure." Turn this off. That will take care of problem 1.
If this also takes care of problem 2, you may want to check whether the UPS has a problem. Start by plugging a couple of lamps with 100 Watt bulbs into the UPS outlets instead of the computer. Turn it on - the lamps should behave normally, not flicker or change brightness. With the lamps and UPS still on, unplug the UPS. The lamps should stay on with little or no change, and the battery warning light should not come on right away. If the UPS fails this test, its battery may need to be replaced or it has a regulator problem.
Posted on Apr 08, 2011
How to use sculpt comffort desktop how o activate it?
You should have received a Quick Start Guide.
Put batteries in Keyboard & Mouse.
If there is an ON/Off swith on the keyboard or mouse, turn them on.
Plug USB dongle into a USB port on your computer.
Start using your keyboard & mouse.
The Product Guide and Quick Start Guide can be downloaded here... https://www.microsoft.com/hardware/en-us/d/sculpt-comfort-desktop
Apr 29, 2014 | Computers & Internet
A1200Y won't start
Dead CMOS battery does not cause the problem you are describing. More likely your southbridge chipset is defective on your motherboard. Replace the motherboard.
May 30, 2010 | HP Pavilion a1200y (EK457AV) PC Desktop
2 cpu and a kvm sharer swith problem.
That switch is power activated - the kb and mouse are assigned to first one that starts and the second pc thinks that it doesn't have neither keyboard or mouse attached and freezes.
Before starting the second pc manually change the assignment.
Feb 15, 2010 | Computers & Internet
All in one computer and mouse and keyboard are not responding.
Check your keyboard is working or not by accessing your BIOS by pressing del or Esc or F12 (usually) or whatever your boot up screen says. If your keyboard works there then the problem lies in the operating system.If still your keyboard doesn't respond then replace the keyboard.
only if keyboard work, you can fix mouse opearting system problems.
For windows Vista & 7, expand "Mice & other point devices".right click on Microsoft Ps/2 mouse" select uninstall and restart the system.If your mouse is still working the system will automatically installed the mouse driver.And your mouse will work again.
Otherwise get a new mouse.
Note: Check you have wrongly insert the mouse 7 keyboard port at the back too.
Remember : Green for Mouse
                   Purple blue for keyboard
Dec 22, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
Internal mouse will not move and lights are red/orange
this might be a problem with the mouse lock..
check ur mouse lock button just above the mouse pad.
if its locked, unlock it & try again.
if its not locked, then go to device manager via right clicking My Computer, properties
select mouse device & expand the tab
uninstall the mouse, dont worry it can be done without mouse.
now press the windows key from keyboard, and restart ur system via pressing Start key, +u, +r for windows Xp & for Windows Vista, press ALT+F4 then select restart.
After ur machine boots up, it will automatically detect the mouse & reinstall the required drivers. its done
if u like my post, pls rate me.. i really need some good ratings..
Thanks
Nov 27, 2009 | HP Pavilion dv9000z Notebook
The ps2 ports for both keyboard and mouse do not work. i got around that by hooking both up with a usb connector. BUT when the computer is on with no mouse activity for a while, the mouse ''dies.'' Then...
HI,
Go into the BIOS utility and set the BIOS to defaults, hit F10, save the changes and exit the BIOS, the computer will restart, see if that helps.
To get into the BIOS hit the Esc or Del key when the computers just starting up.
Good luck.
Sep 14, 2009 | E-Machines eMachines Desktop PC
Keyboard freezes in safe mode after starting windows xp
try the following steps:-
1.If it's a USB keyboard, try a different USB port or try a PS2 keyboard.
2.If it's a PS2 keyboard, check the pins on the plug. Unplug it and plug it back in.
3.Try booting up without the mouse plugged in.
4.Try a different keyboard.
5.If you have VPN or dial up software that has a custom GINA, try uninstalling it under safe mode.
Jul 19, 2009 | Computers & Internet
2-port KVM switch mouse & keyboard connected to wrong display
I have installed several of these KVM switches before... that's not normal. It sounds like there's a manufacturer's defect which is causing the video to link up with the wrong keyboard/mouse cables. If you just bought it, I'd recommend returning it and getting a replacement.
May 16, 2009 | Belkin F1DK102P 2-port KVM Switch
New HP keyboard & Mouse not working
I solved this problem by
1taking off the tower cover
Jan 22, 2009 | HP P2360AA Keyboard/Mouse
Key board and mouse is locked
Try plugging an external keyboard and/or mouse.
See if that works.
Oct 25, 2007 | Compaq D70045-236 Tablet PC
Intel DG965RY Motherboard Logo
61 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
