There is asmall piece of paper jamed in the printer, please tell me how to remove it thank you.
    Guru:
  • 352 Answers
With Tweezers and a very bright torch, pull any paper trays out and the panel off the back of the printer to make it easier if possible.
Regards GM
Posted on Apr 08, 2011
Why my printer is asking me to open rear cover to remove the paper; while there is no paper jamed.
Open rear panel and use a good flashlight and you will probably find one small piece of paper fragment. Use tweezers to remove. Thank you and please leave feedback.
Jul 11, 2016 | Xerox Phaser 3200MFP All-In-One Laser...
Says paper jammed i pulled out still says paper jamed
When you removed the paper did it tear or it came out in one piece.
If not there will be a small piece of paper left inside and this needs to be removed.
Apr 15, 2012 | Canon Office Equipment & Supplies
Paper jamed, but no paper in it?
Somewhere inside your printer is a tiny piece of paper that is causing it to send you that error message. Break out a flashlight, remove your paper and cartridges and search thouroughly.
Nov 11, 2009 | Office Equipment & Supplies
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
Paper jam
Remove the toner, and try to gently pull out the paper jam.. If the page gets torn, or ripped, make sure you have all the pieces of the paper removed. Then re-start the printer. Print a test page to make sure the paper path is clear..
Nov 21, 2008 | HP LaserJet 4L Printer
Paper jam
give this a shot
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 08, 2008 | Brother Multi-Function Center MFC-665CW...
Paper Jammed
Remove all the cartridges and look around. There may be a small piece of paper torn off inside the machine on a sensor.
It is possible a sensor has come loose or a spring has come off of one of the actuators.
Check carefully.
Feb 11, 2008 | Sharp (SHRAM900) All-In-One Laser Printer
Paper jame
This machine only has 3 or 4 sensors
1- In the paper tray to tell it it has paper
2- right before the toner telling it it has fed the paper or if it jammed
3- at the exit of the fuser
4 it may have another one at the very top where the paper is exiting.
If there is no paper on any of thaose then you have a bad sensor/or it is out of place.
Nov 29, 2007 | HP LaserJet 1320n Printer
Jamed Printer
There is an online guide to clearing a paper jam on the link below: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00057157&lc=en&cc=us&dlc=en&product=311255&lang=en Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 11, 2007 | HP Officejet 5510 All-In-One Thermal...
13 people viewed this question
k24674
jasbo
jasbo
