Question about Dryers
My Kenmore 90 Series electric dryer makes a humming noise when I push the start button. It heats up, run for a short while, then stops. Before it stops there is a clicking noise like a circuit or safety switch clicks the dryer off and theres a burned smell like the motor or a belt is burning. Then when you try turning it on again, it just makes a humming noise and don't spin. Is it the motor or what could it be? Please help, thanks.
  • james Ivan
    james Ivan Apr 08, 2011
    Do you have access to a Multi-meter, to test Ohms, power, and continuity of various circuts?... If you do have access to this, do you know ow to use it?... I ask this so I can dfecide the best way to describe the diagnosis and ultimately he repair. It might not be your motor... and it MIGHT be your motor. I would check all the thermostats safety switches located inside the electrical heating coil, the but from the "clicking" and "humming" sound you get when it clicks off, I am more in agreement with you on the cursory diagnosis that it may well be your motor.... How old is the machine? can yo tell me the exact make nd model number as well as the year it was manufactured, I will need to download he wiring diagram for your particular machine.
    Thank-you for answering my email t5o you.
    Sincerely,
    Jimmie James 44
    Problem Solver:
  • 11 Answers
There's possibilty that the bearing is going bad. It would cause the belt to slide alittle when the drums starts to turn. The strain on the motor because of the bad bearing can cause the motor overload and shut down until it cools, then it can be restarted.
Posted on Apr 09, 2011
I have a kenmore 90 series dryer- It is not working - when I push the start button there is a humming noise and the dryer does not start. However if I push the start button and rotate the drum manually the...
You have a "Dead Spot" in your Motor...When you rotate the drum you move it from the dead spot and it continues to run as normal.
If you want to solve that problem then you will need to replace the motor...otherwise just live with it.
Free Answer...Please rate me
Apr 15, 2011 | Kenmore Dryers
Kenmore 90 series... you push the start button and it hums but stops when you release the button and there is no movement with the tub
The infinity start button detent has broken.
Replacing the switch will get you up and running again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 01, 2010 | Kenmore Dryers
Dryer makes buzzing noise but will not run.
that is the sign of a bad dryer motor-sorry-mike
May 08, 2009 | Dryers
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
Kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 80 series dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
246 people viewed this question
Top Dryers Experts
